Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Refidgerator freezer door on fridge doesnt close tightly--seal seems to be ok
  • 828 Answers
Check for possible products keeping door from fully closing, Check level of refrigerator and possibly raise the front adjusters found at bottom front near each corner.
Posted on May 02, 2008
596.77277790 freezer ice buildup in front top corner
If your refrigerator is fairly new, the seals probably are OK. More likely, the door alignment has to be adjusted.
Jan 01, 2014 | Kenmore 22.4 cu. ft. Bottom Freezer...
My freezer door doesnt close fully, the seal is poor & a constant draft flows from the freezer. My fridge door seals properly. You can actually HEAR the difference in the quaity of the seal (the...
Sorry to read about your problem, I hope this helps you out.
The total gasket must get replaced...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
The freezer door pops open when the refrigerator door is closed. A service man already looked at it and leveled it, but it still is a problem. The freezer door has a tight seal when used on its own.
It does this because as you close the door, the air pressure goes to the freezer somehow, maybe through a venting that vents cold air from the freezer to the fridge. The resulting pressure in the fridge, goes to the freezer, and opens the door.
Nov 27, 2009 | GE GTL22JBPBS Stainless Steel Top Freezer...
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Both Fridge and Freezer quit working properly at the same time.
I will need the model number as shown in photo below where the locations are most likely to be. While I am waiting I am going to go over some models like yours to see what may possibly be wrong.
http://servicepartstec.blogspot.com/e6dabfb.gif
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Jan 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
