Question about Nokia 2126 Cellular Phone
I have a nokia tracfone 2126. It won't ring vibrates only how do I turn back on the ring?
How do i take ring/vibrate off and just have ring so I can hear my phone ring?
it depends on what phone you have. Go to the tracfone website and pick out your phone - then you can click to view the manual.
Jul 08, 2014 | tracfone.com
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
Need loud ring ton
Try turning on the vibration setting on your phone. Maybe that will help you know when the phone is ringing along witht he ringtone. Once the volume is all the way up, that's about all you can do. Good luck!
Oct 21, 2012 | tracfone.com
What profile should i use?
Hi there, it all depends on your phone and where you are. For example General is loud silent is obviously silent and meeting it will not ring but only vibrate. Just try them all out.
Jun 11, 2012 | Nokia 2126 Cellular Phone
Won't turn on just vibrates and flashes contiuously
I thought you problem is related to software,,so if you want to do it by yourself Click here1. or contact your nearest mobile repairing shop.And for your file (if you provide me the exact model) follow this link Nokia flash file and select your phone type from the left hand side of the web page.Good luck
Feb 09, 2012 | Nokia 2126 Cellular Phone
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
Vibrate
1 go to settings
2. ring style
3. click the little button top left on phone under "select". it will let you change your ring style
4. scroll to vibrate
5. click same little button under "select"
6. keep clicking "back" - the little button top right on phone under "back"
Jan 29, 2010 | Motorola Mobility TracFone C139-4 Cellular...
My service is disabled.
Double check your cell number on your Prepaid menu. If you have been out of area for any length of time, it may have been changed. If this is a Tracfone, give the 800 number a call (which you probably did.) They can confirm if minutes have been added from your purchased card.
Mar 08, 2009 | Nokia 2126 Cellular Phone
TRACFONE
Take the battery out and put it back in. This will fix it.
Jan 19, 2008 | Motorola Mobility TracFone® V170 Cellular...
LCD screen rolling
try by restoring ur handset or else u need to replace the display...
Aug 15, 2007 | Nokia 2126 Cellular Phone
Nokia 2126 Cellular Phone Logo
118 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
