Question about Tricity Bendix TM310W Electric Dryer
Condenser dryer is operating (turning) but there is no heat?
  • Tricity Bendix Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 20, 2010
2 Suggested Answers
rogrrabbit
  • 986 Answers
SOURCE: Hoover Condenser Tumble dryer HSC 170 not heating up
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 27, 2009
My electric Asko t 721 dryer is not heating
You may have an open thermostat or burned out heater element. The easiest and safest way to diagnose the problem is to unplug the dryer, open the control panel, and use an ohmmeter to check for resistance between the temperature selector switch and the opposite leg of the 240 V plug. If it's open at both the medium and low heat terminals, check the thermostats. You'll probably need a wiring diagram to identify the connections - they're color-coded to make it easier.
Aug 03, 2015 | Asko T721 Electric Dryer
My beko condensor dryer not heating up
beko condenser dryer not heating up any solutions
Feb 07, 2011 | Dryers
We have a miele dryer T 234 C and a recent has
Hi most likely seals on heat exchanger (condenser unit).
Lock heat exchanger in place.the should no movement at all.if movement you will require a rear seal for heat exchanger.Where heat exchanger seals in condenser box clean with scourer. check bottom of door seal for debris.
Mar 23, 2010 | Miele Novotronic T220 Electric Dryer
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
I have a Whirlpool Dryer Model number GEX9868JQ0 and it will run however; it is not blowing hot air? How do we remove the kickplate (front or back) to check out what is wrong? Please advise.
A typical problem that causes tumble dryers to stop heating up is the thermal overload cut-out devices. These are safety devices, and are some times "single-shot". That is, if they operate, and shut off the heating element, then they need to be replaced, usually as a pair along with the thermostat (they look very similar). The other common fault is that the heating element fails. However, if the thermal cut-out was the problem, LOOK FOR A CAUSE. If it is a condenser drier, check the condenser box is not clogged with lint/fluff
Oct 30, 2009 | Whirlpool GGQ8831L Gas Dryer
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Condenser dryer cutting out
Hi
There is typically a thermal heat sensor AND a thermal trip. I suspect the heat sensor is fluffed up too...
Oct 10, 2007 | Bosch Axxis WTL 6003 Electric Dryer
Condenser Dryer turns but no heat
Check with multi-meter for power on the heating element's tags (115/220V). If it does get power,you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Aug 21, 2006 | AEG T57800 Electric Dryer
Tricity Bendix TM310W Electric Dryer Logo
85 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
ptpumpman
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
