Question about Philips 32PFL5403D/27 32 in. LCD TV
HI FEW DAYS AGO I GOT VOLTAGE PROBLEM. AFTER THAT MY LCD Philips LCD TV 32PFL5403D GOT SOME TROUBLE. IT STARTS BUT COULDN'T SHOW ANY PIC LIKE DVD, COMPUTER, SATELLITE RECEIVER & CABLE ALSO. WHEN I CHECKED MY TV TO PHILIPS SERVICE CENTER REPRESENTATIVES, THEY TOLD ME THAT, ITS CIRCUIT BOARD IS AFFECTED & U NEED TO CHANGE FULL BOARD... SO IN THIS REGARD UR HELP IS NEEDED.... THANKS JALAL AKBAR
    Top Expert:
  • Philips Master
  • 74,887 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Posted on Jul 25, 2017
  • 173 Answers
SOURCE: Poor Picture Quality on Philips 42PFL7962D
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one...
no other issues only a minor problem..
Posted on Dec 05, 2007
  • 133 Answers
SOURCE: Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Posted on Jan 10, 2009
SOURCE: Small flickering green line on my lcd screen.
I had the same problem, and I just updated the tv's drivers to the new 1.15 version. I don't see the green anymore.
Posted on Mar 20, 2009
dsacco86
  • 1077 Answers
SOURCE: My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 15, 2009
SOURCE: I Have a Philips LCD TV model#30PF9946D/37.
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Posted on Nov 03, 2009
Philips 32" tv will not turn on flashing three
hi,
You have to check the power supply of you tv for any voltage missing. also check the back light inverter board for any short circuit in it. Inverter transformers in the back light controlling board can become faulty.Three blink indicate the power supply have some problem. First of all replace all the electrolytic capacitors in the power supply board. If filter capacitors in the power supply is bad then this problem can occur.
ok
Jun 09, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
I cannot install terrestrial digital tv on my Philips LCD TV 32PFL5403D/10 and it states that it has a digital tuner installed.
DVB-T can be translated in Mpeg 2 or H.264 (Mpeg4) format. Check if you have correct tuner installed for you local provider
Jun 02, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
Screen keeps cracklin then picture goes off its doing it evey few mins i have to turn it off then back on again to get pic back
This is the same problem I've been having. My display died a few days ago. Repair guy said walmart will end up replacing it or refunding my money. had this tv for just over a year
Feb 23, 2010 | Philips 47PFL7403D 47 in. LCD TV
Jul 15, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
Picture In Picture Feature
Hi LEE,
I just went over the specs on the 42PFL5603D. It doesn't have PIP. I'm sure the guy in the shop was confused with another TV.
There is a software upgrade for that model TV. It wouldn't give you PIP. But, It will fix some of the problems they are have with the TV right now.
Hope I answered your questions.
May 28, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Music on DVDs is louder than the dialogue.
In the Audio set up menu, see if there is a setting to turn off surround sound. I believe it's in your owners manual also. LMK
Feb 28, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
Philips 32PFL5403D/27 32 in. LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
