Question about GoVideo Go Video VR3840 DVD Recorder/VCR
I have duraband video/dvd player model number adb2737bds , dvd works fine but video is not sending signal to tv
    Sergeant:
  • 252 Answers
You have a bad video heads please have tech replace
Posted on Aug 19, 2010
Can durabrand function with dvd?
What is the exact model number to your Duraband TV? Without this detail, how can one post a solution to your problem?
Nov 16, 2012 | Durabrand Televison & Video
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    I have a PS42B541 plasma TV and a 1080P9 DVD player, but the HDMI interface is not working at all. The DVD player is sending the video signal to the TV, but not the audio signal. Also Anynet is not working...
    This is a compatibility problem between this model of samsung dvd player and samsung B model tvs. the only solution to fix this problem is disabling anynet option on samsung B model tvs.
    Mar 02, 2010 | Samsung DVD-1080P9 DVD Player
    No video signal on hd tv by toshiba. could it be
    check that you are getting signal from the dvd player by using another tv, if it works the dvd player is fine(which u have determined anyway) also check the input on tv to ensure that the input ccty (circuitry) is working as well. if the dvd player is working and tv signal is being picked up, check all the plugs and cords. Good luck.
    Nov 16, 2009 | Televison & Video
    Sony DVD Player worked fine forever, suddenly gets 'No Signal' on
    check the video is going from output on the dvd player to the input of the tv. Good Luck.
    Nov 12, 2009 | Televison & Video
    The Emerson TV won't respond to the remote
    If the Duraband doesn't work the Philips remote below worked on mine. If it doesn't then it probably is the sensor. I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
    with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
    May 11, 2009 | Emerson EWF2006 TV
    Can't receive proper dvd/vcr signal
    Your Toshiba TV uses the American NTSC standard.
    Your DVD/VCR uses the Australian PAL B/G standard.
    Unfortunately the two are not compatible as they stand, but there may be an option in the DVD/VDR menu to force the output to NTSC. This varies from make to make.
    Another option would be to modify your main DVD player to make it multi-region so it will play ALL of your DVDs. Some models can be modified with a simple handset code, some can be modified with a software update, and others need an internal modification.
    Post your make and model, and I can advise you on modification.
    May 14, 2008 | Televison & Video
    Recording
    if u mean vcr. dvd burner combo, yes u can, , u can also tranfer from any video source such as a cable box, camcorder anyting that has a video out to your video in on your burner will work
    Nov 21, 2007 | Televison & Video
    Video output not working
    it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
    Feb 25, 2007 | Kenwood DDX-6019 Car DVD Player
    Televison & Video Logo
    103 people viewed this question
    Top GoVideo Televison & Video Experts
    Demonic-2011
    Demonic-2011
     Grubhead
    Grubhead
    Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
