Fabric softener compartment filling up with water and staying there after each wash. have taken bottom part of wahing machine off and opened the dial to let excess water and other stuff out. many thanks
  • finnaddict98 Jun 15, 2008
    Same deal with my Maytag Neptune front loader....the fabric softener compartment will not fill with water and drain into the machine at all. The smae amt of softener remains in the compartment. Any suggestions as to what caused this and what I can do to fix it?
    Scholar:
  • 58 Answers
Im guessing its a top load.
usually that water is from detergent that got down it and harden clogging line
sometimes its just spill over water from another compartment, as long as your fabric softner is dispensing you are fine
if you acutally want to fix it you have to take off the drawer and clean tubing, some use wire hangers, and pour hot water down line, but this can rip line.
but alot of time this water is normal from spill over
Posted on May 02, 2008
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Iwd71250uk fabric softener staying in dispenser.
Compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow the grid.
Cleaning the detergent dispenser drawer
Remove the dispenser by raising it and pulling it out (see figure below). Wash it under running water; this operation should be
repeated frequently.
25825864-ineink0kisfnom0atbkujjcx-3-10.jpg 25825864-ineink0kisfnom0atbkujjcx-3-3.jpg 25825864-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Aug 17, 2015 | Indesit Washing Machines
How do I get fabric softener to flow into washing machine
jrez's answer is for toploaders... you said you have a drawer, so it's a front loader.
The softener is usually taken up by a syphon. This can be removed from the drawer assembly for cleaning, when they clog they can't syphon.
While the machine is taking water for the last rinse, some of the incoming water is sent via the softener compartment. As softener is thick, without a syphon the softener would just sit in the bottom of the compartment and the fresh water would just skim off the top.
SO: Check the drawer after the final rinse.. if the softener compartment is full to the brim, the syphon is blocked. OR .. if there's just the same amount of softener as when you started the cycle, you have a filling problem instead.
Filling problem can be for two reasons: early machines had one water valve, and a flap which squirted water into the various compartments, operated by a linkage from the timer - this linkage can break, the spring can fall off, all mechanical. Later machines use a separate water valve, and this can fail shut.
Feb 15, 2015 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener compartment is filling up with water.
the hose need to be clean there is something that let the water get stuck there check inside if you see what is cluge in the unit or the internal hose, try to clean it with warm water
May 23, 2010 | GE Energy Star WCVH6260F Front Load Washer
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dispenser still full of water and fabric softener
fabric softener This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 15, 2006 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
261 people viewed this question
Top Washing Machines Experts
