Air conditioner runs hot and then cool, intermittantly.
    President:
  • 3,773 Answers
Compressor is being shut down as it gets hotter.
Check condensor coil for cleaning
Check Compressor. relay
Checkcold control (Thermostat)
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 19, 2010
Stops running thermostat
thermostat or relay module issue.
May 19, 2013 | Dometic Rooftop RV Air Conditioner
My LG lp1010snr AC's compressor only seems to run for about 3 minutes on and 3 minutes off, is the compressor being this intermittent normal or is there a problem?
This is called short cycling and it is a problem. It sounds like the compressor is getting hot and shutting off on a thermal overload. When the overload (bi-metal contacts) cool from the compressor being off they close and the compressor begins running again. The refrigerant gas cools your compressor windings, so there may a restriction present or a leak, which would cause the compressor to get hot and open on overload. This is not good for the compressor and will eventually ruin it.
Aug 03, 2011 | LG Heating & Cooling
I have a 13,500 Dometic A/C that usually blows cool air but sometimes changes sounds and blows hot air for a while before switching back to cold. What do I need to fix?
Could be the compressor overload on the way out. Or an intermittant temp control. Or it might just be a loose connection at the junction box between the roof and the base.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 04, 2010 | Dometic Rooftop RV Air Conditioner
Does it need a hose to release the hot air
Yes, you need to have a hose on the outlet where the hot air comes out and run that out through and window or something to the outside.
If you do not do that it will not cool because you are just running the hot air back into your space that you are trying to cool.
heatman101
Apr 08, 2010 | Amcor AF9000E Portable Air Conditioner
Central Air Runs But Doesn'tAlways Cool
Yes it could be low on refrigerant. The other cause of ice-ups is poor air flow caused by a dirty filter or intermittent blower failure. If it's low on refrigerant there is a leak and it should be found first.
Aug 11, 2009 | Carrier 38CKC042 Air Conditioner
Air conditioner is set on cool & furnace is turning on
probably your compressor not running or the air con is out of Refrigerant.
Jun 06, 2009 | Intertherm P3RA-048K Air Conditioner
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Air Conditioner Smoke
The smoke you are seeing is the cold air turning the hot humid air into a cool mist. This may happen when you first run the a/c to cool the room. Once the room is cooled down you should not see the mist any more.
Jul 09, 2007 | Maytag M3V08S2A Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
