Question about Denon AVR-589 Receiver
Receiver: Denon AVR 790 I get a "H/P input on" on the display then I hear a clicking sound like a "relay" clicking, then the sound goes off. It is not overheating as it is not enclosed in a cabinet and is not even warm. I am using HDMI (monster cable brand). It normally happens after approx 2 hrs from turning it on.
I had the same problem as you did.. i found out that all i had to do is blow the dust out of my head phone socket and the problem was resolved. i now this sounds crazy but it worked.
Posted on Aug 22, 2010
  • 11 more comments
  • freakedout Sep 07, 2010
    You are a God! I had the same problem - blew air into the headphone hole and problem solved! Weird but happy!
  • jmartin911 Sep 21, 2010
    same problem also .... your solution to blow the dust out of the headphone jack worked like a charm!!!!!!!!!!!!!! Denon people could not even figure it out. Thanks soooooo much.
  • bentownsend Nov 03, 2010
    Have the AVR-1709 with the same problem. Can't believe blowing into the headphone jack worked! Thanks for the suggestion!
  • 909502 Dec 06, 2010
    I've just spent 2 hours trying to troubleshoot my audio and multeq disapearing from my Denon AVR 589. I began searching the internet for any mention of this problem and came across this chain. Blowing air through the headphone socket worked like a charm!!! Unbelievable! Denon needs to include a can of air with every box.
    Thanks!!!
  • brzysio Jan 19, 2011
    It worked for me too. I also spent about 2 hours trying to do the setup, reset, etc. And then google came to the rescue. I still think that Denon shall be sold by a pound. I had my avr 589 serviced 3 times in the first 2 months after purchase. When it dies I definitely go back to sony. Thanks for the tip anyway!!!
  • Anthony Tsaukpaetra Feb 13, 2011
    Unbelievable. We should make this the top result in google! We were seriously considering returning it!
  • Jaredmelliot Mar 05, 2011
    Thank you same issue with my denon2310. Worked perfectly.
  • leoob Mar 27, 2011
    I had the same problem with my dennon AVR. I thought I would need to replace it. It is hard to believe but this solved the problem for me too
  • 4SeeCraig Sep 10, 2011
    I can't believe this worked. How dumb is this problem. Thank you all.
  • funtgifguy Sep 20, 2011
    This has been driving me nuts! Started looking in the maual for help. Not there. Found this on line. FIXED IT!. Thank you for posting this. Now I watch TV without the NOISE!
    funtgifguy
  • Francois Artignan Jun 17, 2012
    Have a AVR-1908 and exacttly the same problem... Blew air into the headphone socket and bam it worked as normal straight away !!! This is mad ! Thank you guys for the solution, don't think I would have ever figured it out without you !!!
  • gordburdick
    gordburdick Jul 20, 2012
    Thanks, such a great receiver...with ***** manual and support !!
  • Anonymous Jun 17, 2016
    Thanks for this! I searched through manuals, looked online, and finally found the advice to blow into the headphone jack of the AVR 790. I did this, heard a clicking sound, and the audio was back on! Many thanks for this!!
How do I switch from HDMI 3 to HDMI 1 on my Denon AVR 790?
You need to do the input assign. The receiver needs to be told which physical sockets are assigned to what buttons. Once you assign the inputs, then press the corresponding input button. So if you assign HDMI 1 to be your Satellite receiver on the TV/Sat button, then you'll get the sound
Sep 04, 2014 | Denon Avr 790 7.1 Channel Receiver Barely...
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
Denon AVR 789 no display
Time to send back to Denon (seriously). Hopefully you have a warranty on your product (I bought mine at Fry's and it took a few months for the warranty work to be performed). Good luck!
Jan 15, 2012 | Denon AVR-789 Receiver
How do I set my receiver to read TV/CBL Dolby Digital. It is a AVR 789
The Dolby digital signal is outputted only through the Optical or Coaxial socket of the CBL box. you will have to get an optic fiber or coaxial cable depending which cable box you have and connect it to the digital input of the Denon receiver. The Denon's digital input are already assigned at the back. Eg: Optic input might be labeled CD so if you are connecting the CBL box to the optic input remember to select CD on the Denon to hear the cable sound, same goes with the coaxial input.
Aug 27, 2011 | Denon AVR-788
I have a denon AVR-1604. It was working fine but started to hear a relay clicking on and off as it was playing. Now when i try to turn it on from standby i hear the relay click as i turn it on with the...
the noise is the speaker protection switch ( reset relay) disconnect all speakers see if it stops if so then conect speakers 1 by 1 untill you find the crossed speaker could just be a crossed wire best of luck
get me back if you need more help
Dec 31, 2010 | Denon AVR-1604 Receiver
I have a Denon AVR 790 for about 8 months now. Hooked up a combo DVD VCR player using the red/yello/white cables. It worked fine for about 6 months. Now I cannot get the DVD or VCR to play. I get sound,...
If dvd combo player is only video source connected with Denon AVR 790 then unplug yellow video wire from Denon and plug it directly in TV input, now video signal will go directly to tv and sound will come from Denon AVR 790 speakers during dvd playback.
This is simple bypass that wont effect surround sound of dvd playback.
Let me know if you have additional question.
Thanks.
Oct 20, 2010 | Denon Audio Players & Recorders
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Denon AVR-589 Receiver Logo
1,514 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
