Question about Dell 962 Photo All-In-One InkJet Printer
Do you need to have a color cartridge in or can you bypass?
    President:
  • 2,571 Answers
Most modern printers need all cartridges to be full or they wont print, so if 1 colour is empty you cant even print in just black.... what a rip off.
You can buy a chip resetter to fool the printer in thinking that a near empty cartridge is full
Posted on Aug 19, 2010
Trying to remove color cartidge error if not using color bliinking orange light
Unfortunately no, Printers require both cartridges to be installed and operational to enable the printer even if you are only printing black text. No way to bypass this "feature".
Feb 15, 2013 | HP DeskJet 950c InkJet Printer
Empty color cartridge error
The printer needs all cartridges with sufficient ink levels for you to be able to print. The printer will prime every once in a while thus the need for all cartridges to have ink - this will prevent damaging the printhead.
May 07, 2012 | Lexmark Interpret S405 - multifunction ...
Have a photosmart 3210 all in one and i just want to print in black and it wont because a color cartridge is empty is there any way to bypass this
Remove the color cartridge, it will run on "Ink economy mode" or something like that. It WILL print from windows but the copier wouldn't work, displaying error. The copier needs both cartridges installed to work.
Nov 04, 2009 | HP Photosmart 3210 Printer
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
Using one cartridge
There are printers that require both the black ink and the color ink cartridges. Unfortunately, you'll need to have both and at times needs them to be not empty for a printer to work. It usually doesn't matter whether you're printing colored or just black.
Sep 16, 2008 | Office Equipment & Supplies
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Oct 23, 2007 | Epson Stylus Photo R220 InkJet Printer
Brother Intellifax 1840C
Brother Intellifax 1840C the only one thing you can to do is stick masking tape around the cartridge, there is an switch, when you take off the cartidge the switch is off, when you put it on the switch is on, this is out = "off" and in= "on", do the same with the other colors.
greetings.
May 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Dell 962 Photo All-In-One InkJet Printer Logo
54 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
