Question about Canon PC-940 Black and White Copier
Canon PC 940. replaced a $6.00 roller because bushing broke. Now I get code "EO". any ideas
    Problem Solver:
  • 4 Answers
The heat element is not heating up check the connections at either end of upper fuser roller. unpluging copier for 20 minites should reset the error
Posted on Aug 19, 2010
How can I slove earror EO, in my BW PC-940
You can have this Error Code resolved, I am just not sure that it would be wise. These are the facts. You have a 10 year old machine which has an EO error code which means there is a problem with the Fusing Unit. The parts required to fix the error code are anywhere from $150.00 to $250.00 depending on if you go with the whole fusing unit or just the Fixing Film Assembly which is going to contain the defective part(s). There is some dis-assembly of the machine required in order to replace the parts. If you hire someone to do this you are looking at another $100 to $200 in labor depending on who you call. So you could easily spend $250 to $450 to repair the problem. These type of small copiers are sold brand new at Office Depot and other stores now days for $100.00. They will also have a USB port so you can hook it to a PC and use it as a printer. I am in the repair business and have been for 27 years. I would not recommend that any of my customers make a repair to this machine of this magnitude. I have in fact referred 2 of them in the last 5 months to go buy the new Canon D340 instead of repairing the old one.
Good Luck to you and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Canon PC-940 Black and White Copier
Canon 6551 copier-rollers are grabbing causing smear on the copy
check the paper path you need to control the main drive mecanism, and all bushing roller : registration roller, pickup, fixing and exit: you can see exemple of the bushing to check: mabroukmedal_41.jpg
the roller that you need to check and replace the bushing:
Dec 21, 2010 | Canon NP 6551 Black and White Copier
Canon copier 940 trouble code EO?
Odds are that you are getting a error code E000. It is saying that you have a problem with your fuser unit. You can try to unplug the copier for a short time. But you will mostly need a new fuser unit. Good Luck
Sep 07, 2010 | Canon PC-940 Black and White Copier
My paper keeps jamming in the drawer when I try to make a copy.
clean the feed roller , check the clutch that control the feed roller , check if there is no stack or any object in the paper way, the u can replace the feed roller
Aug 26, 2010 | Canon PC-940 Black and White Copier
Copier wrinkles copies
It cuold be that paper has too much moisture or you nned to replace press roller bushings alonh with cleaner and fixing film
Apr 30, 2010 | Canon PC-940 Black and White Copier
Canon pc 940 no paper pick up and a signal of P in the display panel
You may have a blockage in the paper feed path, or a worn out paper feed roller, or a faulty paper feed drive clutch / drive mechanism.
Can you see if the paper feed roller rotates in contact with the paper?
Are you using plain paper?
Dec 07, 2009 | Canon Office Equipment & Supplies
Where is the fuse on the canon pc-940 copier. It
Why would a fuse have any thing to do with a clicking sound? If the fuser or fixing unit was having a problem you would get a error code. Have you replaced the toner or drum cartridge any time? If so, was the noise there before? If it was not recheck the installation and if you put the old parts back in and you have no noise, it has to be the new cartridge.... Good Luck
Oct 14, 2009 | Canon PC-940 Black and White Copier
EO appears at switch on then machine switches off
EO is a error code. You have a problem with the fixing unit. You will most likely have to replace the Upper Fuser Unit....
Aug 21, 2009 | Canon PC-860 Black and White Copier
PC745 error code - what is it. Source for manual?
that is the symbol for a paper jam. the figure 8 represents the rollers and the zig zag is the crumpled paper.
Dec 27, 2008 | Canon PC-940 Black and White Copier
Eo-10 code
hi im jules_09,no the copier is not dirty or jammed,if there is a paper jam it will indicate paper jam there is no error code for that,if the copier is dirty you can see it in the print.reset the error code in the program,if the error code is still there checkfusing unit then the optic sensor
Nov 02, 2007 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
97 people viewed this question
old marine
old marine
