Question about Hiro V.92 56K AGERE Chipset PCI Fax Voice Modem( XP 64bit Vista ready/ Linux / RoHS) [H50006 - LINUX... (FM-H50006)
I have a Hiro V.92 56K only good up to Windows Vista. Is there a driver download that will allow me to use the with Windows 7?
3 Suggested Answers
  • 5100 Answers
SOURCE: Scanning the document
I'm confused? The listed product is a Fax/Modem, not an all-in-one. It doesn't have a scan function. To send a document via a fax, you will need to scan it with a scanner (separate hardware) and then fax it. In Windows 7, a program called Windows Fax and Scan is included. If the devices are installed with the correct drivers, you can do the two steps in one program. Open the program, click on New Fax. Select Insert > Pages from Scanner (only available if the scanner was on and connected when Fax and Scan was started). Scan the document; fill in the contact information for the receipient and send. The Contact information may take a few steps since it is a Windows Contact page.
I hope this helps.
Posted on Apr 09, 2010
  • 133 Answers
SOURCE: i want to purchase the nexxtech usb 56k modem for
If there are even Linux drivers for this product, it is likely that they are already included with the distro and thus you do not need to download anything.
Posted on Apr 21, 2011
Hiro h50015 nic on windows 7 says network cable unplugged when cable is clearly plugged in
To connect to the internet, you must have a device like a modem or a router. Is your PC connected to this device? Do you have other PCs or networked devices on your LAN? Can you reach them with ping?
To make it easier to help, you should give information how your network looks! e.g.
internet ---- cisco800 router --- d-Link switch ---- myPC
or something like that. Otherwise it is fooling around in the dark.
Apr 13, 2014 | Hiro H50015 Network Adapter
Tip
Install Unsigned Drivers on Windows 7 & Vista with Driver Signature Enforcement...
Every time when we try to install any hardware drivers which are not signed by microsoft, Windows shows a warning of Unsigned driver dialog box. The reason of showing warning message is to protect the stability of your Windows operating system as such drivers are not passed in Microsoft windows driver compatibility test.
In Window XP you can still install unsigned drivers but in Windows Vista SP 1 and Windows 7 Microsoft has introduced very restricted module of driver signature enforcement which doesn’t allow us to install any incompatible unsigned drivers.
If you want to bypass or disable Unsigned Driver warning message then Here is small freeware utility Driver Signature Enforcement Overrider which allows you to install and load unsigned drivers dynamically on your Windows 7 and Vista.
Supported Operating System
1. Windows Vista 32-bit & 64 bit
2. Windows 7 32-bit & 64-bit
Download Drive Signature Enforcement Overrider 1.3b
Please Note: User Account Control (UAC) must be disabled in-order to use this tool.
on Jan 10, 2010 | Computers & Internet
Emachines G640G 6670M
Open Device Manager, Uninstall the Graphic Card and driver, reboot the machine, allow Windows 7 to apply the generic driver, Open Windows Updates and run. OR, open Device Manager, display adapter, update Graphics adapter. OR, Use the eMachine windows vista 64 bit drivers. Download the Windows Vista 64bit driver and Save , open Properties, change compatibility to Windows 7. Take a look at this : http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/
Feb 06, 2013 | Computers & Internet
NEW Pavilion Slimline & NEW HiRO V.92 56K External USB Data Fax Voice Modem Windows 7 Vista XP 32 64 bit. Installed drivers as per instructions. I can see drivers in device manager & under control...
SOP - Standard Operating Procedure for MS OS's (NT, 2k, 2k3, XP, Vista, Win7) - why load
drivers for devices that are not present. If you want to use the modem,
turn it on before powering up the PC.
Also please post the full version number of your driver. Not all of them are fully 7 compatible.
Jan 12, 2011 | Computers & Internet
I need a sound driver for my asus A6R series entertainment nootbook... Model:A6R mb ver: A6RP i do not know much that all information i got from the notebook..thank you..
Sound driver and Audio driver is one and the same thing. I do not know that which Operating system you are using (like Windows xp, Windows Vista and Windows 7). To check this out go to "Computer" or "My Computer" and right click it and then point the mouse pointer to "Properties". A new windows will open and you will be shown the version of Windows (either XP, Vista or Windows 7).
For windows XP download from the following link by copy pasting it in your internet browser
http://www.driverstock.com/ASUS-A6R-driver-download/6-21-10801/index.html
For Windows 7/Windows Vista 6.305 download the
"Realtek AC'97 Drivers for Windows 7/Vista 6.305"
http://www.downloads2k.com/Realtek-AC-97-Drivers-for-Vista.html
For older version of Windows Vista 2.50 use the following link
http://www.filecluster.com/Drivers/Sound-Cards/Download-Realtek-High-Definition-Audio-for-Vista.html
Good luck and take care!
Jul 25, 2010 | ASUS Computers & Internet
Hiro USB modem, vista cannot detect. It is in
I THINK THE PROBLEM IS IT IS ANALOG AND WE LIVE IN A DIGITAL WORLD, MEANING IT PROBABLY ISN'T COMPATIBLE.
Jan 09, 2010 | Hiro (H50113) Analog Modem
I installed windows 7 and now my function keys don't work
You need to install the drivers, windows does not recognize these additional buttons until the proper drivers are loaded. Depending on manufacturer windows 7 drivers may or may not be available. Microsoft did something smart with windows 7 by allowing you to use windows vista drivers in windows 7. So if there are no win 7 drivers just download and install the vista drivers. Good luck!
Dec 04, 2009 | Sony VAIO VGN-A690 Notebook
Usb modem driver
there are other peripherals that conflicts with this modem. try to plug this usb modem alone without other peripherals connected and check. if the problem persists then the modem itself has a problem
Nov 05, 2009 | Hiro (H50113) Analog Modem
Can't find vista driver for this camera
I guess its a USB device. Install USB2.0 driver. That shud solve your problem
May 25, 2009 | Hiro H50071 / H50072 / H50073 Personal Web...
Hiro V.92 56K AGERE Chipset PCI Fax Voice Modem( XP 64bit Vista ready/ Linux / RoHS) [H50006 - LINUX... (FM-H50006) Logo
90 people viewed this question
Top Hiro Computers & Internet Experts
Prashant M
Prashant M
Are you a Hiro Computer and Internet Expert? Answer questions, earn points and help others
