Question about GPX HM3817DT Shelf System
We were away and the unit was off. When we returned and turned it on the AM/FM tuner only gets static. The CD player still works. There must have been a power spike when we were gone. We resert the unit (button) but still only AM/FM static ?
    Problem Solver:
  • 14 Answers
If you've had a power surge and then reset it, you'll need to do a retune as per the set up procedure in your manual.
Posted on Aug 19, 2010
How to get the laser unit repaired/ replaced on my portable CD player?
Most likely cheaper to replace than repair. The labor cost for such a fiddly repair would be more than a new unit.
Jan 22, 2016 | Magnavox 45 Esp Jogproof Portable Cd...
How do I fix the FM tuner to pick up FM signals?
I think you might have fault in the FM tuner section. Most of these are done by a single IC, replacing that will cure the fault I suspect.
Jun 10, 2017 | Audio Players & Recorders
Sony MHC ec77 CD player works fine, great sound but when I switch to AM/FM, why is there no sound although the display shows that is going through the stations?
Unlike old analog tuners, the new digital tuners will not output any sound or static if they do not lock onto a station.
May 06, 2015 | Sony Audio Players & Recorders
Pioneer cd player quit workin and i have static in radio could my fm modulator be bad and can that keep my cd player from working
Your modulator shouldn't effect the cd player. But it can cause static in your fm if you leave it on. Make sure the modulator is turned off before trying to use the regular fm. Also, if its a wired modulator, then check the antenna connections. If it's wireless than it should not effect anything. Depending on the radio, get a aux input on it. Wireless fm transmitters are the worst.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 25, 2012 | Car Audio & Video
How do i get the FM radio to work on my GPX 60 sec portable cd player
After some research, I even read the instruction manual, I found no evidence of an FM tuner in the unit. If you instruction manual say's it does, it should instruct you on how to enable it. I found on the Amazon site no advertisement of an FM tuner as well in the specifications.
Feb 15, 2011 | GPX C3960 Personal CD Player
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
http://www.payphone.com/shop/instructions/Wurlitzerwr18.pdf
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
My Sony CDX-MP70 unit plays CDs and works on aux off my iPod but when I try to listen to am or fm it's nothing but static if I scan for a station it will just search forever, I took it apart but it all...
Check for a loose antenna connection, at the unit and where your antenna is attached to your car. Also, check fuses, some cars have 'powered amplified' antennas.
If those dont work, try resetting the unit. On most units there is a small pinhole behind the faceplate(not on the faceplate). Could also be the internal tuner has gone out...
Hope this helps
Aug 24, 2010 | Sony CDX-MP70 CD Player
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
I have a SANYO AWM-1900U CD player/stereo where I get no AM or FM reception(no static or nothing!)but the CD player works fine. Speaker wires are connected properly I just get Zip from the tuner???
You might have to invest in a proper ariel not the kind you get that you stick on the wall but a proper FM one that sits in your loft on on your roof. Hope this helps.
Oct 02, 2008 | Audio Players & Recorders
Won't tune any stations
To be honest, at that price buy another one. It's not worth fixing. Sorry
Jul 18, 2006 | Jensen JCR-280 Shelf System
GPX HM3817DT Shelf System Logo
147 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
