Question about Cycling
My back wheel makes this *** squeaking sound and i already checked and its not my brake pads
  • SDsherm
    SDsherm Aug 19, 2010
    If you grab the wheel/tire, can you wiggle it left to right?
    Brigadier General:
  • 8,546 Answers
Bearings dry?
Posted on Aug 19, 2010
Front wheel doesn't spin freely and squeaks on 2n'd day i got it.
Hi James:
If New, I'd take it back to the dealer.
If used.....
Set bike on jack so front wheel is raised. Make sure it is secure so can't fall.
1) Remove front brake pads........... spin wheel If it still squeaks, remove wheel and service bearings.
If no squeak when brakes removed, service brakes.
Jan 18, 2016 | Motorcycles
Squeaking and grinding noise when I apply the brakes
Try replacing or resurfacing your rotors and brake hardware. Using brake pads similar to the oem will also help stop any problems.
Dec 15, 2013 | 2005 Pontiac Montana SV6
When i drive over 50k(australia) my front drivers wheel sqeaks and it does it too occasionally when i break. been happening for over 2 months so i rule out that its dirt in the breaks. what could it be...
wow first post ever for country, im GOBSMACKED !!!!
wheel ?steering wheel or tire/wheel.?
hard to find, they are, all squeaks.
first is to see if possible to do, no moving (big safety issue, yes)
bounce the corners of car hard, by hand.?
jack car up spin tires. by hand,
lever them below off ground, to see of balls are shot.
inspections here, look at every inch of suspenson and parts.
Brakes, i hope nothing breaks the brakes.
The brakes all squeak this is normal try lightly pressing the brake pedal, gently while moving slow, squeaking now is 100% normal and harmless. (the pads act like Guitar strings)
Use pad glue to halt it, or ignore it like me....
the pads have wear markers, they have this device that makes noise when pads get too thin, (look at em)
bad wheel bearings.
brake backing plate bent.
caliper guide pins rusted.
and lots of other things bad or just ok , old and making noise, like
suspension "A" arm bushing rusty, or stable bar , same.
moving noise is real hard to find.
Sep 12, 2013 | 1997 Honda Prelude
Passenger wheel chirp / squeak that stops when brake is applied
sounds like a brake pad warning clip is making contact with the rotor applying brakes presses pad and quiets the noise. have pad wear checked by mechanic.
May 17, 2013 | Chrysler Town and Country Cars & Trucks
Squeking wheel off and on while driving
get your car to a service centre immediately, squeaking usually indicates worn brake pads, most brake pads now have things called shims, that let out an almighty strange squealing sound that goes on and off as the wheel turns, as you get faster, it gets quicker, it might be front brakes or rear brakes, but make sure you get them all checked, i have had on more than one occasion, front left brake pads ok, front right low, or rear and vice-versa
Jun 10, 2010 | 1994 Chevrolet Cavalier
97 dodge intrepid front right wheel squeaking
check your brake pads,when they wear down they will make a noise to get your attention to have your brake pads looked.
Aug 12, 2009 | 1997 Dodge Intrepid
Sueaky front wheel
It could be a number of things. First check your brakes for any rocks or excessive dirt. Second, check to make sure you are not in need of new brake pads. Brake pads are equipped with a tab that starts making noise when its time to replace your brakes. Third, have the bearing checked. Once the bearing get excessively worn they will start making a squeaky sound. Also have the shocks checked. the bushing worn out in shocks can also cause the noise. The best bet is to have your local mechanic inspect your front end for any wear. Once he does this, he can compile a list of parts that need replaced. Then you can replace or fix it yourself.
Aug 04, 2009 | 1996 Jeep Cherokee
A metallic squeaking sound from the front driver side wheel well
On your brake pads there is a wear indicator tab. This is a metal tab that protrudes just past where the brake lining almost ends. It is there as an indicator that your brake pads are nearing the end of their life cycle and it is time to change them.
Please remember to rate this solution.
Feb 13, 2009 | 2006 Chrysler Sebring
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
