Can i use the capacitor 1000mf/6.3 volt in place of 680mf/4 volt?
  • 61 Answers
No is not able although the same micro farad and volts
Posted on Aug 19, 2010
Mitsubishi ws48515 when plugged in hear a click and the green light starts blinking and set does nothing
This is a common problem with this unit.
1. Un plug the unit.
2. Take the back off of the unit
3. On the far left side you will see metal box standing up. Inside the box is your DM board. Remove the box from the unit.
4. Remove the DM board from the box.
5. Inspect these Capacitors to see if they are bulging or defective.
C81A2, C81A3, C81B3 and C81B4. The Value of these capacitors are 1000MF/16V
6. If any of these capacitors are defective, replace them all with capacitors at this rating. 680MF/16V
7. Make sure that when you replace the capacitors that you have the correct polarity. The - side of the capacitor goes toward the markings on the board.
8. Reinstall all parts of unit.
9. Plug in unit
10. Wait the 90 seconds or so that it takes for the DM to boot up ( Green Flashing Light )
11. Once Unit stops flashing you should be able to turn it on and enjoy.
Good luck to you.
Mar 20, 2013 | Televison & Video
Green timer light no picture
Also known as the Green Blinking Light of Death.
The repair on this is cheap but very time consuming and wit no gaurentees.
There are 4 Capacitors on the DM board and 4 Capacitors on the Formatter board that are more than likely defective and need to be replaced.
On the DM board the locations are C81A2, C81A3, C81B3 and C81B4. They will probably be swollen.
On the Formatter board the locations are C8F19, C8F21, C8F22 and C8F27. Also will probably be swollen. The values of all 8 capacitors are the same. 1000MF/16V. Replace with value 680MF/16V.
While you have the chassi ripped apart, check the power supply board as well. You should fine some swolle caps on it also. Replace with same value of the one you remove.
Now once all of this is done and you put everything back togeather, you have a 50/50 chance of success. I have found that many surface mount caps can also go bad on the formatter board. If your repair does not work, then replace all of the surface mount caps on the formater board that are 10 and 16 volts.
Good luck to you.
Mar 19, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Hello, My LG suddenly stopped turning on and the only thing I notice is a continuous Red flashing standby light. It slowly lights up to full size then goes back off then repeats the same thing...
Change capacitors. The 1000mf, 680mf, 470mf ones (your monitor should have totally 5 or six of them. When you open the case you'll see the bad capacitors ready to burst on the top. Change with same capacity. No problem if you replace 16V with 25V capacitors -> "Equal capacity in mf, equal or bigger voltage"
Mar 01, 2011 | Televison & Video
Red lights is on and when I go to turn on the TV the green light only stays on for 1 second.
Your external power supply is the culprit. The small box that is connected the outlet plug is bad. The TV itself is fine! The external box has a bad capacitor inside. You will find a 16 volt 1000MF capacitor at 105 degrees that is bad and next to that one is a 25 volt 1000MF at 105 degrees, replace as well! Show this info to your TV tech or hobbiest and repairs will be at hand. Thanks for asking and good luck!
Jun 30, 2010 | Proscan 19LA25Q 19 in. LCD Television
Power does not turn on on our 19la25q. Red light flickers, but does not turn green when trying to turn on.
The external power supply is the problem. The small box that is connected to the outlet plug has an internal problem. If you can get inside of this box, you will find a capacitor, 16 volts, 1000MF at 105 degrees . Replace with same value and the capacitor next to that one is a 25 volt 1000MF at 105 degrees. Replace as well with same value! Ask a TV tech or a hobbiest to do the work for you. Thanks for asking.!
Jun 10, 2010 | Proscan 19LA25Q 19 in. LCD Television
Blinking grenn light want come on.
you have a bad digital module, when it is bad you get a constant flashing light that won't quit, if you have some skills, remove the digital module, replace all of the 1000 micrfarad at 16 volt capacitors with 1000 mf at 25v, or 680mf at 25v, this will fix your problem. you probably need a qualified tv repairman to fix this.
Sep 15, 2009 | Mitsubishi WS-65869 65" Rear Projection...
I am having a problem with my Samsung LNT4661FX/XAA
http://techreport.com/search_google.x?cx=010312586752609289257%3Avgpois-b0yw&cof=FORID%3A11&q=LNt4661fx&sa=#692
check this link for more info on the power supply problem.
May 01, 2009 | Televison & Video
Bad Mits capacitors
You can get the full service manual at the following link that will show you how the chassis is removed and then its just reverse the proceedure. Heres the link.
http://servicemanuals.vstore.ca/
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Projection Tv
?? give description of problem?? plug it in and hookup some cable!
Jun 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi HD1080 TV will not turn on.
On my Mitsubishi WD65-613 it was 4 capacitors on the DM board. They are 1000mf 16v, replaced with 4 1000mf 25v. TV is working great.
Nov 02, 2007 | Mitsubishi WS-65615 65" TV
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
