Question about Sony BRAVIA KLV20G300 20 in. EDTV-Ready LCD TV
Not sure of screen size but our tv was working and then it was not. Cannot turn it on. When we unplug and try to re start it is just dead. If you press the on putton then a red light flashes twice on and off on the bottom of the tv. Any suggestions
  • 11,361 Answers
Right now the standby 5vdc power supply is working but not the rest of the circuits, this can be due to short circuits in the other section of the power supply or in the main board, backlight inverter board.You will need to do in-depth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 19, 2010
I have a Sanyo DP42841 I cannot adjust the screen size. When I try to adjust with PIX SHAPE I can get the big screen 4 but all the others are a box with gray bars on both sides. Interestingly enough
Roger, you might try this.. on some TV's it works. while it is unplugged push the power button on the TV and hold it in for 30 seconds or more. sometimes this Resets the tv back to Default setting. Hope this helps besides even if it doesn't work you haven't hurt anything or lost anything..
Jan 27, 2015 | Sanyo Televison & Video
We were watching tv and the screen went black, the sound got quieter and then it turned off. We left it overnight and now it won't even turn on. The red light isn't on to indicate the tv is off. We...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem...
Jun 26, 2011 | ViewSonic N3252w 32 in. LCD Television
I turn the tv on and I hear a click and the green light comes on but no picture or start up screen
Tries unplug tv and any cables or satalites boxes,replug it all back about an hour later.The tv will reset it self,and those boxes will upgrade it software.The tv,should work again.Not,than the Tuner board is dead.That the board,where the incomming broscating signal cable plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Aug 26, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
I can't get picture on my TV. It essentially won't turn on.
Look for caps and see my pictures to see what bad caps look like, you may ahve dead inverter board.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 18, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Black screen and whistles
Sorry to say that it sounds like the high voltage went out on that one. The sound that you hear is probably the high voltage arcing across the flyback transformer. Dont try to make any repairs here. The unit has at least 25,000 volts in there. Even long after it has been unplugged. I'm not sure what size TV that is from the description, but you would be looking at replacing the main deflection board, which may well exceed the value of it.
Apr 13, 2009 | Televison & Video
If i turn off my tv it wont turn back on
This problem is either the TV's software or how the mainboard is distributing power so instead of just unplugging the TV, try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power/on-off button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
Since hardware either works or it doesn't, your issue is either software or power related since you can get it to work so hopefully the power drain will indicate further.
Mar 25, 2009 | Proscan PS36109 36" TV
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Sony BRAVIA KLV20G300 20 in. EDTV-Ready LCD TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
