Question about Concept P1020 Car DVD Player
My car tv does not turn on and all the fuses are good
  • 17,130 Answers
Since you are sure about the fuse why not see if the monitor unit gets the power or if there is a line break. If the power does come to the main board in the set, check if the regulator in the front end power is supplying the supply to the main IC.
Check the signal from the player to the monitor, if possible test on your TV with an extended cable.
However if the power and the signals are normal, then it is possible that the monitor IC has failed.decide with the cost and availability if reasonable.
hope this helps.
Posted on Aug 19, 2010
My bauhn tv isn't turning on at all. I was watching a show and it just turned off and now the standby light isn't turning on.
Hi Anonymous,
The power supply in your tv has gone dead. If you can, open the back cover, check the fuse, replace it if it is blown. If the set works well and good and if the fuse blows again, consult some local TV Tech.
Good luck.
Jun 30, 2015 | Televison & Video
TV turns on then turns off right away
In an answer to your problem, fuse could possibly be good and not blown
basing on your post "
TV turns on then turns off right away "
A fault or two have been detected so the TV will automatically shut off
to prevent further damage.
You will be needing tools, equipment , good vision and a lot of
patience when working with TV.
here is a troubleshooting guide should you need to DIY
Flyback Transformer
• Must have supervision of a qualified service technician
let us know if you need further assistance.
Sep 23, 2012 | Toshiba 32HFX72 32" TV
TV will not turn on. The fuse is blown. Need to
hello,
replace the fuse with the rating of 2.5A,
you can also check the iron head of the fuse.
Good luck...
May 25, 2010 | Televison & Video
My screen went black while watching tv a fuse or somthing else?
If your TV makes ANY noise at all while trying to power up(turn on) then your A/C FUSE IS GOOD.
Relay makes a clicking niose when TV is turned on.
Any led that lights up while trying to power up set>>A/C fuse will be good!!!
May 19, 2010 | Sylvania LC420SS8 LCD TV
My tv model ws65315 green ligth turns on and then turns off and the screen doesn't turn on
The TV probably has the -27 volt fuse blown. This fuse will blow when your convergence amp IC's have gone bad (STK-392-250)
Call a good TV Tech.
Jul 30, 2009 | Mitsubishi WS-65315 65" Rear Projection...
TV will not turn on
Good Morning Chris,
OK, first of all lets unplug the TV and wait 15 minutes for the High Voltage to discharge.
Remove the back and follow the power cord to the power supply. Somewhere around there you should find a fuse. (there may be more than one) get a bright light to look inside and try to find as many fuses as you can. Remove each fuse one at a time and check them with an ohm meter.
If you don't get a good solid reading on any of them replace the fuse or fuses with the exact same rating. Even if you get a reading and the display is jumping around and will not stablize, replace the fuse. Usually a good fuse taken out of the circuit will display a good steady reading on the meter.
I hope this solves your problem.
Have a great day!
Mar 26, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
JVC AV-36260 TV Problem TV won't turn on
  • blowing fuse is a short circuit problem in your tv.
  • please do not replace fuse unless you know the reason otherwise it may damage tv.
  • fuse blowing is due to
  • main filter capacitor
  • power output transistor sort or regulator short circuit.
  • good luck
Oct 21, 2007 | JVC AV-36260 TV
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Concept P1020 Car DVD Player Logo
108 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
