Question about Frigidaire Microwave Ovens
Neither the bake element or broil element works on my Frigidaire galley stand up oven. getting no error messages and relays are clicking in.
  • 2 more comments
  • toms378 Aug 19, 2010
    not a microwave it is a smooth top range/oven
    i have the back panel off where would the thermostat be located?
    I AM ON A FRIGIDAIRE SITE THEY SAY MY MODEL STOVE DOES NOT HAVE A THERMOSTAT
  • toms378 Aug 20, 2010
    GLEFSS77CQB IS THE MODEL NUMBER
  • 10,865 Answers
Hello Tom. If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Posted on Aug 20, 2010
  • Frigidaire Master
  • 2,605 Answers
Hi, welcome to FixYa.
Can you provide a model number please ?
macmarkus :)
Posted on Aug 19, 2010
    Sergeant:
  • 252 Answers
The thermostat that tells your oven when to shut your element off in order to keep the proper temperture has gone bad.
After I replaced the lower coil in my Frigidaire oven, the self cleaning part does not work.
Hi Carol Eggers, thank you for your inquiry!
I understand that your wall oven is not allowing you to perform self-clean after you replaced your bake element. It sounds like it could be an issue within the control panel or sensor inside of your oven. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire FPMC2785KF Professional 27...
Galaxy oven does not work
you might have a bad element. Check for continuity.
Jun 24, 2012 | Microwave Ovens
All i know about my self cleaning oven is that it is a frigidaire. it was here when i moved in. i want to use the self cleaner but i have no idea how. nothing on it is digital. its all knobs. i have no...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 09, 2011 | Frigidaire Microwave Ovens
Electric range with es 100/105 electric oven, getting no heat to oven or broiler. how to fix this problem
My lights turn on Range works but the oven and broil doesn't. Is this the relay or the Thermostat??
Jul 16, 2011 | Frigidaire Microwave Ovens
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
Microwave not heating
In all likelihood the Magnetron, or Power Diode has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 26, 2010 | GE Microwave Ovens
All works but no heat
oven with no heat. check bake and broil elements. if test ok, then check for thermal fuses in back. sometimes they r resetable
Feb 07, 2010 | DeLonghi Microwave Ovens
When oven is in on postion oven element does not come on but broil element does;when in broil position nothing happens and indicator light is dim when in off position but burns bright when in oven...
sounds like you have a bad control board.or you have crossed the broil element wire witha bake element wire.these are the first things to check
Jan 22, 2010 | Microwave Ovens
Wont heat
Hi!
Here are two instances when this happens---
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Microwave Ovens Logo
74 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
