Question about Dell 924 All-in-One InkJet Printer
Dell printer all in one 966 error 1243
After refilling the cartridges i got this error, what can i do ?
  • 1 more comment
  • blackbird966 May 02, 2008
    error 1243
  • Anonymous Aug 08, 2008
    i have the same problem cartridge message error help
  • agallo Sep 14, 2008
    Can someone help me? I have a 966 dell all in one, behind the cartridges there is a rubber chain band that guides the cartridges back and forth. Well the band came off and so dis the white gear.
    Scholar:
  • 41 Answers
If u have the new cartridges then replace it with the refill, it will resolve your issue
Posted on May 03, 2008
Dell all in one printer 964... Error message 1203... What does this mean? I recently had the ink refilled at Walmart. The printer did work after the ink was refilled, but now it's being very odd and will...
Hi there
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
All the best Pineworks
Apr 27, 2010 | Dell 966 All-In-One InkJet Printer
Help me with cartridge error #1203 please
Ok it worth a try
or
Apr 15, 2010 | Dell 966 All-In-One InkJet Printer
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
Error 1203 is a very interesting error code. Here is what I found out about error 1203
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
Refilled Ink Cartridge on Dell 966 all-in-one,how do i reset it?
I had this same printer but never was able to reset it. It has some type of sensor on it. That will not let it reset. I was told to unplug it from the computer. Turn the printer off. Reboot the system and plug the USB connector back into it once the system is booted. You may also try to reinstall the printer driver. I also find out that when the printer software says that the ink is low, it really is not. So keep on printing. What I eventually had to do is get a HP. No problem with HP, I can get a refill and it works. Now that I am think about this. See if you can disable the ink monitoring option in the software.
I hope this helps.
Please rate.
Feb 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Printing
or
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2009 | Dell 966 All-In-One InkJet Printer
Dell 966 doesn't recorgnise lexmark cartridges
I don't understand the printer message. Even though it may be "compatible" to a Lexmark, you may have to get the Dell cartridge because it will only recognize a Dell branded cartridge. At least try to reinstall the old one and see if you get the same message. If you do, then you may have a printer problem. If not, then the cartridge is the culprit.
Jan 24, 2009 | Dell 966 All-In-One InkJet Printer
Dell 966 all in one printer
when you replaced the cartridge you didn't ran a page Alignment go to control panel
printer options
go to properties and
run a page Alignment
Jun 05, 2008 | Dell Office Equipment & Supplies
Dell photo 966 error 1243 incorrect cartridge
is it a refilled cartridge? if it is it wont recognice it u should just buy a new one or keep printing if it lets u because i had the same problem and i had to get a new cartridge because it wouldnt let me print at all
May 02, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
90 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
