Question about Palm Vx Handheld
I have an old palm pilot vx and I cant recalibrate the screen without a hard reset and losing all my info! Its stuck on the opening screen after a soft reset, because I can't get to the home page. The pointer is all over the place! Any ideas?
You can change the function of any of the buttons at the bottom to open a different application. Here's what I did. I never use the To Do button so I went to Pref and changed the To Do button from To Do to Welcome. Now if it needs to be recalibrated, I just press the To Do button and it opens the Welcome screen. I can still access To Do from the main menu if I want to use it.
Posted on Apr 01, 2011
Cannot digitize
After looking at MANY posts on the web, I resolved this issue by repairing a corruption in my outlook data. I thought I needed new hardware and there are those that will sell it to you but note this fix and try it first. Yes, your outlook data issue can mess up the palm data and system and create problems with the touchscreen and digitizer such that you can't use the stylus and/or cause an endless digitizer loop even after resets.
To repair your outlook data create a shortcut to your "scanpst.exe" on your desktop and run the repair from there. You need no new software - this file is in windows office already and can be found through a system search or web search if you don't know where it is.
Apr 01, 2010 | Palm Vx Handheld
Stuck on digitizer screen as well
Remove the Screen Protector from the device and then complete the recalibration. Check if the device is charged to full.
Jul 21, 2009 | Palm Zire 31 Handheld
I forgot the password to my sprint palm cento HELP!!
you can do a hard reset to unlock but you lose all your info unless you have synced it with a computor, im sorry this is the only way to unlock it :\
Jun 10, 2009 | Sprint Palm Centro Smartphone
I bought a refurbished Tungsten E. Because there was some incompatibility with the software version of my other Tungsten (which is on its last leg), I downloaded new software off the internet. In the...
Are you syncing the new device to the same username in Palm Desktop as an older device?
If you are, this will cause problems on the new device. When you sync the device, it saves the device settings, 3rd party apps, preferences, etc. in the backup folder in the username folder on the PC. When
you sync the new device it copies the contents of the backup folder for the old device to the new device. This will cause corruption in the settings for the new device thus causing erratic behavior of the new device.
Looks like you may need to hard reset your device and rename your backup folder
Go to http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=887 and follow the directions to do a hard reset. Next before you hotsync your data back over you will need to rename your backup folder, to do that go here;
XP
C:\program files\palm or palm one\[hotsync username]\ and rename your backup
folder to backup.old
Vista
Start-->documents\Palm OS Desktop\[hotsync username]\ and rename your backup
Then hotsync to your current hotsync name and all your contacts, calendar,
tasks, and memos will come back over.
Show file extensions for XP or Vista
XP
If you can not view file extensions on your PC I would like you to open a
folder go to Tools-->Folder Options--> View (tab) and under show hidden
files and folders uncheck hide file extensions for known file types.
Vista
Open control Panel go to Folder Options--> View (tab) and under show hidden
Mar 28, 2009 | Palm Computers & Internet
My palm is not working
Had the same problem. You will have to hard reset - in doing so you will lose all data on your device. Sorry I know no other way.
Step 1: Charge your device overnight.
Step 2: While holding down the reset button (back of unit) hold the power button down. Release the reset and wait for the Palm screen to appear. When it does, release the power. Press the "up" button when prompted for full restore.
You should now be working. Word of warning: I continue to have problems with HotSynch. The version recommended by Palm (v. 4.1.4) locks up my system, as if it is emulating another device (no buttons work, screen wonky, etc.).
Best of luck!
Jan 12, 2009 | Palm Vx Handheld
Forgot my palm pilot password
You will need to do a hard reset...this will wipe all the data and reset it back to factory specs...
1...While holding the power button, use the tip of the stylus (or a similar object
without a sharp tip) to gently press and release the reset button inside the hole
on the back of your handheld.
2... Wait for the Palm Powered™ logo to appear, and then release the power button.
3... When you see the message that warns you about erasing all of the info on your
handheld, do one of the following:
• Press Up on the 5-way navigator to finish the reset and show the touchscreen.
• Press any other button to do a soft reset.
Jan 11, 2009 | Palm Z22 Handheld
Palm Pilot will not turn on
I remember the Palm Pilot days, and the rush to buy them. If you make sure you're grounded (static electricity is deadly to electronics) I don't think there is too much risk in taking the unit apart, assuming you have some screwdriver skills. I have taken them apart without any issue, and iirc, the button wasn't too hard to get to once you get the screws out (four maybe?).
Good luck, and let us know how it goes. I know how frustrating it is to have a great bunch of data in limbo.
Jan 03, 2018 | Palm Pilot Professional
TREO Screen freeze?
Have you reset the unit by taking the battery out? Power it up after doing so, just like a home PC - it should work again.
If that does not work, the touch screen driver may need updating...
- J.
Feb 22, 2008 | Palm Treo 650 Handheld
Serial USB connection to an old palm
This is a common issue, you might want to try these, in hope 1 of them will work: - make sure there's no problem in the configurations of the devices and their both connection is to USB. - there's probably a collision with anther device that is connected to the palm, try doing uninstall to everything, do a hard reset, run " activesync" or " hotsync" and reconnect. - there's maybe a problem in the drivers, try reinstall them. - if you are using 3.16 pm, there's probably a collision
Feb 23, 2006 | Palm Vx Handheld
Palm Vx Handheld Logo
80 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
