Question about Dryers
Gas dryer tumbles no heat.
I have a whirlpool that wont heat. No lint checked that. Gas going into dryer check. Good voltage in plug check. Plugged in check. When started the dryer tumbles, after 2-3 seconds the igniter glows for 8-10 secs w/o ignighting the gas. I have listened for a click but am unable to hear well enough to tell if it is or is not clicking. What next!?
I would change out the igniter, When they start failing hey will glow but not draw enough amps to open the gas switch / valve.
Posted on May 02, 2008
I have a Kenmore 600 series gas dryer it has stopped heating. When you first turn it on it heats right up like it should then after jus a min the heat stops and it wont blow any more heat what could it be?
The majority of the time this problem is because the dryer vent is plugged. Remove the vent hose or pipe and clean it out, removing all lint buildup. Check the damper door where the dryer vents outside for obstruction. Make sure your lint filter and the area it goes into are clean as well. This will fix the problem 9 times out of 10.
Aug 02, 2013 | Whirlpool LGR3624JQ Gas Dryer
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
No heat. all sencors in back including element check good and have been replaced but still no heat.
I'm sure you've cleaned your lint filter, but you also need to make sure there is no lint blocking the silver dryer hose. Mine gets plugged at the exit from the house and once I remove large amounts of lint, I have heat again. Also, if it's a gas dryer, is your pilot light lit?
May 04, 2011 | Whirlpool Dryers
The unit would start tumbling and the heating mechanism light the gas but for a shoprt time only. @ 3 minuts of flame then shut down and the motor now wont turn. i have good 110v to all parts
It sounds like you have a plugged vent or a crushed vent check behind the dryer to make sure not smashed and go outside and check the duct vent door...
Apr 01, 2011 | Dryers
Dryer runs but no heat this is a gas dryer
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Whirlpool LGR3624JQ Gas Dryer
My gas dryer does not heat at all. I behind the lint screen was full of lint. I cleaned that out and still does not start to heat. Can you tell me what I should look for next? Thanks,
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it
Sep 20, 2010 | Whirlpool GGW9200L Gas Dryer
Gas dryer not heating all the time
Good Luck!!
Jan 27, 2010 | Whirlpool LGR5636PQ Gas Dryer
Gas dryer quit heating
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
161 people viewed this question
Top Dryers Experts
