Question about Ortho Dial N Spray Hose End Sprayer
Using Ortho weed and crabgrass concentrate... what setting do i use on my Ortho hose end sprayer
  • 2,019 Answers
Here is what they say at their site:
How do I use the Ortho Dial 'N Spray Multi-Use Hose-End Sprayer?
Pour product into jar, and set dial to amount indicated on product label and begin spraying. This sprayer siphons product and mixes while spraying; it does not mix inside the sprayer.
http://www.scotts.com/smg/catalog/productTemplate.jsp?bodyCssClass=scotts+blade+scotts+product+faqhelp+en&tabs=help&navAction=push&bodyId=product_faq_help&proId=prod70022&title=p_product_general_help_title&itemId=cat50094&id=cat50008
Which means it is not determined by Scotts, but by the product you want to disperse with the Dial N Spray.
And here is an exact description of the settings:
{ ... There are 14 settings in all and they range from 1 teaspoon per gallon up to 8 ounces per gallon. You will find the dial at the on the top of the sprayer. ... }
http://www0.epinions.com/review/Dial_N_Spray_Hose_End_Sprayer/content_465229876868
Posted on Aug 19, 2010
What is the mixing ratio to 1 gal of water?
Their products are here, but they don't tell you the usage. It has to be on the label by law. The rear label usually lifts up to reveal a small book of three or four pages. If it isn't there, contact the company via the website.
http://www.spectracide.com/Products-and-Solutions/Lawn-Weed-Killers.aspx
The does have label details here
http://www.spectracide.com/Customer-Help/Labels-and-MSDS.aspx
For the Spectracide it is 1/2 oz to a gallon, but it depends on what type of grass you have. I will copy and paste the label details, but I doubt the format will stick, but it is all there.
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
I use a powder fertilizer in my sprayer. What is the "ratio" of this sprayer? I use setting 4.
Directions on the sprayer are not the factor here, the directions for use on the product are. In any event we don't have this info, if you are unsure call the manufacturer or contact a garden supply shop. DO NOT USE TO HIGH A CONCENTRATION, IT WILL BURN THE PLANTS.
May 18, 2012 | Ortho Dial N Spray Hose End Sprayer
I have the Ortho Dial and Spray and am applying the Round-up Weed and Grass Killer. States a 6 oz feed rate per gallon and that this should cover 300 sq.ft. I pour 24 oz into the container which should...
I'm sorry to hear about the problems you had with the Ortho Dial N Spray. This hose end sprayer empties about 2.1 gallons per minute, so you will need to walk fairly quickly to cover area you're wishing to apply product to. Please give Ortho a call at 877-465-5160, and we will be happy to assist you further.
Hilary @Ortho
Sep 03, 2011 | Ortho Dial N Spray Hose End Sprayer
I need a nozzle for the Ortho Dial N Spray Multi-use hose-end sprayer. I cannot get an answer back from Ortho on how I can get the part. How can I remedy this situation without buying another Dial N...
Sorry to hear about the problems you are having with your Ortho Dial N Spray. Please contact Ortho at 877-465-5160 and we will be happy to help you further.
Hilary @ Ortho
Aug 29, 2011 | Ortho Dial N Spray Hose End Sprayer
I am confused. Your driveway weed killer says 1 quart per one gallon of water, and the dial n spray has just ounces on the top up to 8 ounces and up to 32 ounces to be filled on the side of container....
Hey, sorry for the confusion. Actually Ortho GroundClear can not be used in the Dial N Spray Hose End Sprayer because this sprayer will only dilute up to 8oz per gallon. This dilution rate is not enough for the product to be effective in keeping the area clear of vegetation. Hope this clears it up.
Hilary @ Ortho
Aug 21, 2011 | Ortho Dial N Spray Hose End Sprayer
How long should I wait to determine if my application of Weed B Gone is 'working'?
Weeds treated with Ortho Weed-B-Gon Chickweed, Clover & Oxalis Killer Concentrate will show visible signs that the product is working within 1 to 2 weeks. A repeat application may be necessary in 2 to 3 weeks for hard-to-control weeds. Initial signs that the product is working are wilting and yellowing of tender new growth. Necrosis (tissue death) then spreads to the rest of the plant. The weeds wither, turn brown and die.
Sometimes it appears that weeds are still growing and going to seed even after they have been treated with Weed-B-Gon Chickweed, Clover & Oxalis Killer Concentrate. These seeds will be sterile because the chemical will have reached them within 1-2 days of treatment. If you have any further questions please feel free to contact Ortho @ 1-800-225-2883
Mar 07, 2011 | Ortho Chickweed Clover Killer Pint
I need the owners manual for the ortho dial n spray hose end sprayer.
From forums.gardenweb.com
"The instructions on Ortho Garden Disease Control (Daconil) give directions for use in the dial and spray. Set dial at 4 Oz. Add 1 TBS Daconil and 7 TBS water for each gallon you want. I am using the dial and spray and don't see as much residue as when I was using a pump spray.
Jul 03, 2010 | Ortho Dial N Spray Hose End Sprayer
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Ortho Dial N Spray Hose End Sprayer Logo
836 people viewed this question
Top Ortho Garden Experts
raysaw
Tom Chichester
Are you an Ortho Garden Expert? Answer questions, earn points and help others
