Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
ON MY LCD TV I HAVE A RED LIGHT, GREEN LIIGHT, AND A AMBER LIGHT ON THE RIGHT SIDE, THE AMBER LIGHT STAYS ON AND I CAN'T GET A PICTURE BUT I COULD HEAR VOICES.
  • duke1590 Aug 19, 2010
    the screen is blue and sometimes channel 1 is frozen on the screen. what does the amber light mean, when it's green the tv is on, when red it means the tv is off.
  • duke1590 Aug 20, 2010
    i have one more question, the switches on the right side of the TV do not respond by pushing the bottuns, and the same for the TV remote control , Would you say that the tuner should be replaced.
  • 10,594 Answers
If tv screen is just black then it sounds back light inverter board problem that is not producing light in lcd panel to show its image.
Check at rear of tv for bright white light coming from any vent holes, if no light found then back light is not working.
Point flash light on tv screen and try to observe faint image in screen that is another evidence that back light is not working.
Local tv repair shop will help you replace back light inverter board to fix tv problem.
Let me know if you have additional question.
Thanks.
Posted on Aug 19, 2010
  • Shahid Electronics
    Shahid Electronics Aug 19, 2010
    OK, please disregard back light inverter answer/ solution as I thought tv screen is just black.
    Now I got update that tv screen is blue that shows that signal processor is not working properly due to weak cable signal or bad tuner.
    Please attached dvd player with tv and check does it tv show correct picture of dvd playback?
    If tv show correct picture in dvd playback then problem could be cable box/ connection and/or tuner in tv.
    Thanks
    Shahid Electronics Aug 20, 2010
    OK, unplug tv from wall socket for minute or so to get it reset, replug back in and turn it On.
    Does it cure switches problem?
    If tv is 2-3 years old then check power supply board and specially electrolytic capacitors in output section that board that seems defective and could give such problems.
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
SANYO LCD 24K40 TV instead of Red or Green the power indicator display Amber color
press the helpful button,
the amber light may be for stand by or sleep mode, go into your tv setup and check that these are turned off
Jan 12, 2016 | Sanyo Televison & Video
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Sony tv prolem
If the red light that stays on says lamp check the lamp or replace it-- it may not look bad to be bad.
Apr 19, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Thomson topupbox
hi i have sorted the problem i went on line of the make of the thomson freeview and their was other people with the same problem and they help me by reading their instrutions on their page now it is working .
May 04, 2009 | Thomson DTH8000 DVD Recorder
Protron 26' t.v
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 30, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Orange/amber light
the orange lamp is suposed to be on when the set is off but there is still power to the set
red will be on when in standby
green when set is on and working
Dec 19, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
165 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
