Question about Linksys WAG200G Router
How to intall wag200g on bsnl broadband line?
Bsnl broadband configure
the router without any Modem WITH internet is useful. You must have Moden with BSNL broaband. Remember the router the only function is amply the signal for internet for use in wireless.
God bless you
Jul 11, 2013 | TP-LINK TL-MR3420 Wireless Router
I have a router and switch d-line brand,how to bsnl broadband connection give to multi user
CONFIGURE UR ROUTER WITH BSNL. THEN CONNECT SWITCH TO LAN PORT OF THE ROUTER.CONNECT THE MULTIPLE PC TO IT
Dec 22, 2012 | Computers & Internet
I am unable to open many sites while using bsnl broadband..
BSNL have aways been known for its network problems
there are many websites actully lakhs of domains who are not authorised for use in bsnl domain.
SO. its better you try switching to some other broadband or 3g connections other than bsnl
Dec 27, 2010 | Computers & Internet
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
How to see bsnl broadband bill on net.
use dataone.in their check your account status to check your bill
Apr 11, 2009 | Computers & Internet
Adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
Sharing
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Feb 08, 2008 | Paradyne (6211-A2-200) Router
Linksys WAG200G Router  Logo
285 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
