Question about Nelson Sprinkler: Traveling Tractor
The stop button is pushed in and will not pull back out
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
Should the switch be pushed in or should it be up
push type kill switches ( emergency stop buttons) press to stop power
they have to be generally twisted and pulled up to turn the power back on
Jan 30, 2017 | Motorcycles
The hour hand on my tag chronograph does not stop at 12 when you reset the chronograph
Try pulling out the crown to the first position. Then push upper and lower button simultaneously. The red stick will start moving 1 second per push. Repeat procedure until it reaches zero position, then push back the crown to the normal position.
Sep 25, 2011 | Tag Heuer Kirium Quartz WL111E.FT6000...
The sweep hands don't align back to zero after replacing battery
Pull out the stem to the second position then push the chronograph start/stop button a few times to move the minute hand to the zero position. Then pull the stem out to the 3rd position and adjust the second hand again by pushing the start/stop (top) button to move it to the zero position. Once you get them both to top zero push the stem back all the way and screw it in tight. Tim
Jun 21, 2010 | Watches
Stop watch not zeroing
Pull out winder 1 step and us the push buttons to adjust hands to 12 o.clock . when you have done this pull winder right out and use push buttons to set other hands then push winder back in.
Jul 06, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
The seconda had does not stop at the top of the watch. It stops at the "2" and I need to reset it to stop at the "12".
Pull out crown to the date setting position and then push and hold upper push button (at 2 o'clock). Adjust hand and push the crown back in. After that adjust time and date if necessary. Rate me, plz.
Feb 26, 2010 | Maurice Lacroix (IN3022SS001320) Wrist...
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
1996 Lincoln Mark 8 Inside Trunk release Button Stopped Working. The button pushes down but doesn't click like the gas tank release button does.
possible bad button. pull button out and pull wire off the back and touch together and see if trunk opens. possible bad relay for that circuit or blown fuse.
Jul 18, 2009 | 1996 Lincoln Mark VIII
Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
Dec 25, 2008 | Fossil CH2470 Watch
How do I set the time on a invicta model 4232
Your invicta has a three setting button,the two is push button, and the center a button is to wind button or crown, To set the crown you pull it,has a two pull the half pull and full pull , the half pull is for the date setting and the full pull is for the hour and minutes. The two push button is for the stop watch,the above button for stop and go,, the lower button is to reset button .Just try to function the push button and observed what happen. feel free for further assistance in keep sending more question in comments or doubts that arise your mind regarding this to me,,rate the as fixya if it helps you understand in solve your problem....
Jun 18, 2008 | Invicta Watches
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Nelson Sprinkler:  Traveling Tractor Logo
70 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
