Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung hlr5067 Hi i have the same problem and can not figure out what to do
Lamp led lights , screen is dark
Posted on Jun 18, 2008
Samsung HLR5067 has no green color in picture
I know this may seem dumb but if you are using component video (the red green blue with the white and red audio cables) it could very well be that the green cable (carries the green signal) is the problem. try changing the configuration (ex: use blue to carry the green signal and vice versa) if the green starts to work and the blue stops then its just your cable.
Oct 18, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Samsung DLP HLR5067 modeel tv, recently we have replaced the lamp, ballast and color wheel. The color is ok but when we watch dark (color)movies the black and browns look shadowed and irdescent. ...
You probhably have the wrong color wheel. There are several different ones and its imparitive that you replace it with the correct one. If you search here theres someone else that had the same issue and when they put thier old noisy color wheel back in the problem went away.
Nov 15, 2010 | Televison & Video
I have a HLR5067-W. I heard a single pop from the
Does it still making noise now?Than yes ur color wheel is broken need it replaced.
Nov 23, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
My samsung hlr5067 displays check fan #2 then will shut off
Well there is a possibility you might, if the fan doesn't look good I recommend you replace it. But don't go too far, maybe you just need to take off the dust on it.
Jul 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Clicking Noice after replacing shattered color wheel, ballast and lamp...
Not sure if this will help but I read in the manual that if you have
a clicking sound that the cable setting and the air setting are both turned on...Good Luck
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP color has gone Muted...Color Wheel or Bulb???
The color wheel or lamp ballast needs replaced...it would be hard to know which without being there to look at to fix the humming problem, neither part is that is that expensive if you price shop, you may want to try one at a time ot save money. Also to fix the picture you need to realigh the DMD board with the help of another person watching the picture.Hope this helps.
Dec 30, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
