When i switch the computer on the fan automatically switches itself on, the problem has only started this week . i have a phillips MT1100
  • 149 Answers
What fan????
How is it a problem, the fans are supposed to run every time the cpu is on........
Did the fan used to come on at all???
The fans are sometimes active in monitoring temperatures and will speed up when required, maye your Mainboard is dusty and gets too hot too quick, Blow the dust away with a compredded air can. DO NOT HOOVER as this causes static and can be fatal, to your cpu
Posted on May 02, 2008
  • 197 Answers
What fan is switching on is it the cpu fan or the internal fan that cools the tower
What would cause a toyota corrola cooling fan fail to start automatically when engine is hot.but fan runs continously when you disconnect thermal switch.
Disconnecting the thermal switch or temp sensor puts the engine computer in limp mode and the computer will activate the fan relay to prevent overheating.
The temp sensor could be faulty, or something is not telling the computer the engine is hot enough to need the fan.
Sep 28, 2015 | Toyota Cars & Trucks
My Phillips radio displays ERR CODE, how do I get rid of that and unblock it
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
This make take an hour or more
Make sure you have the correct code
Apr 02, 2011 | Car Audio & Video
My panasonic fan has been working fine for the last 4 years. now, it seems to have trouble starting up... when i flip the switch on, it seems to start and re-start itself, turning itself on for 2 - 3...
Sounds like it could be a loose or intermittent wire either in the fan itself or in the wall switch. I would start with the wall switch to see if the main power line into the switch for both the fan and light is loose. Turn the circuit breaker off for that circuit, remove the wall plate to the switch and pull the switch out of the box to examine the wires. It could also be a loose wire in the switch box that would be part of a wire splice. Tighten the wire nuts. If that does not fix the problem, a look inside the power box of the fan might be necessary to examine the wire connections there.
Sep 12, 2010 | Panasonic WhisperFit-Lite Low Profile...
Computer wont stay on
One week old? Take it back to where you bought it.
Nov 02, 2009 | Acer Computers & Internet
My fan switch stopped working on setting 5 and then 2 weeks later
check your fuses1st then check to see if power is reaching fan if it is the fan may well be er um stuffed thats a start or switch maybe er um. or possibly dust in switch try that and come back with more info youdoit
Jul 25, 2009 | 2006 Chevrolet Trailblazer
I'm using a pentium4 processor with Inter motherboard. When I switch on my computer, it automatically get turned off.. what is causing this?
when ever you start your computer it gets switch off ,,there are many reason
1.check that *********** boat fan is working properly ,check the fan should not be blocked with rubber bands ,if the rubber band blocks it and the fan is not able to rotate then the computers switches off which even happened to me
2.maybe a problem is the power supply in the mother boat
3.check windows is insalled properly if now install a new windows from doss
Nov 21, 2008 | Computers & Internet
Fan Honeywell Chronotherm IV T8600
sounds like the fan has been programmed to come on during that time. run through your programming settings and make sure the fan is set to auto for all the times.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Mind of it's own
your remote and fan is set to someone elses frequency by little toggle switches
you will have to remove fan to where it hangs make sure power off
find the remote sensor inside electric case at ceiling in the fan
this is a dip switch to control frequencies
09c4f2f.jpg you will see something like this adjust the dip switches
means change the dip switch for fan
then on remote open the remote battery pack find the dip switch in there
change those dip switches to the same as in ceiling fan
put fan together and turn back on power
your fan should now not pick up the other frequency of another remote and they have a span of about 50 yards to pick up frequencies
Jun 07, 2008 | Hampton Bay 24002 Ceiling Fan
Pc uprade
u can use 1 gb 400mhz DDR ram,single or 2
Mar 01, 2008 | Intel Motherboard
Clicking and power cycling
Possibly it is overheating and saftey mode is starting automatically (Phillips/Panasonic)which will turn the overheated components off and leaving the fans on trying to cool the device whilst resetting the overload switch mechanisim (hence the clicking) Or possibly the power supply may be on its way out (this will happen between 3-7 Yrs dependant on use)and it is constantly trying to switch on the power supply until the power supply activates correctly. I would take this device to a quality repairer and request a bench test with a written diagnosis or report under the guise of wanting too know the condition of the device as u have just purchased it. If/when under bench test conditions the fault replicates itself your repairer will advise you of the problem parts and repair costs within the write up for the bench test or verbally at the time of pickup.
May 17, 2007 | Sharp Notevision PG-M20X Multimedia...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
