Question about Motorola Mobility H700 Wireless Headset
Nedd the passkey to pair to my blackberry - Motorola Mobility H700 Wireless Headset
  • 229 Answers
Problem :
Passkey to pair
Solution
PUT THE HEADSET IN PAIRING MODE
The headset indicator light will be steadily lit in purple when in pairing mode. To place the headset in pairing mode:
If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple.
If the headset has previously been paired with other devices, first ensure those devices are turned off.
Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple.
DEFAULT PASSKEY is 0000 (four Zeros)
Rate my solution please
Posted on Aug 19, 2010
FreeTech
  • 426 Answers
SOURCE: blackberry unable to pair with motorola h500
the pass key is "0000"
Posted on Jul 16, 2008
  • 4 Answers
SOURCE: numeric passkey for h710 pairing to 8830 Blackberry
the default code should be 0000
Posted on Dec 24, 2008
  • 23 Answers
SOURCE: pairing my blackberry curve8310 to a motorola H700 headset
when pairing a handsfree device to your phone the typicaly generic passcode is 4 zero's (0000)
Posted on Mar 12, 2009
remaker
  • 449 Answers
SOURCE: pairing my H680 asks for passkey - ??
In most cases they passkey is 0000 or 1234
Posted on Feb 05, 2010
SOURCE: jabra bt2050 passkey 0000 dosent
Try putting in 1111. It still will not engage. But after you do this it will reset. Then put the 0000 in and you will be connected.
Posted on Sep 07, 2010
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
Where do I find the passkey?
the number is 0000 this is a basic passkey for all bluetooth devices.
Jul 09, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Blackberry storm won't accept 0000 as the passkey, in pairing mode
Not all headsets use 0000 as the passkey for pairing mode. Check you manual and make sure that the device your attaching to the blackberry does. If it does, make sure that it has not already been paired with something else.
Jan 28, 2010 | RIM BlackBerry Storm 9530 Smartphone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Need passkey for the pairing for bluetooth with
The passkey in the Phone prompts up only when you are trying to pair your device to another device,
So, you can provide 1234 as the password and another user who is pairing with you should also provide the same,
Incase if it is not working under Generic key or if you are facing any other problem related to Bluetooth pairing, Please contact your Service Providor and check..
What is the passkey to my sony vaio laptop VGN-CS160J
If you have a blue tooth device added to your laptop or build into your laptop, you will have to enter control panel and select Classic View at top left and then select Blue Tooth.
Once you are in that option window you should go to security and set your passkey there and then. When you apply your settings and return to Pair your devices you only need to use the passkey that you have entered at your blue tooth security and you should be all sweet.
Aug 23, 2009 | Sony VAIO VGP-BMS33/B
What is the passkey for O2 Blackberry 8700g & O2 Blackberry 7130g
You decide the passkey and need to ensure you type it in the same format for both devices - It can be anything you decide
Apr 25, 2009 | RIM BlackBerry 8700g
My bluetooth passkey
Passkey 0000 worked for pairing my Motorola HS850 and my Blackberry 8800. Thanks!
Dec 12, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility H700 Wireless Headset Logo
167 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
