Question about Kitchen Ranges
It does not hold the right temp - Kitchen Ranges
  • Kitchen Ranges Master
  • 11,800 Answers
In that case the thermostat sensor is faulty and must be replaced. This is a very complicated job (it involves the practically complete dismantlement of the oven) that should be left to an expert.
The part won't be very expensive - around $50 - the labor for replacement will - expect no less than $300.
Posted on Aug 19, 2010
Ritetemp model 8050c i have to reset it 8-10 times per day if it is set on 74 the setting will always go up to 82 and beyond.sometimes it will go up in minutes How can it be set to stay where i want
Are you using the "Temp Hold" to hold your temp at that temp or changing it without opening the panel?
(To change and hold the temperature until you return. .Open the door and push the TEMP HOLD button. The HOLD icon comes on. Push the UP or DOWN arrow buttons to set the hold temperature. .HOLD is canceled if MODE switch is moved, or by pressing TEMP HOLD again.)
~Eddy
Air Conditioning Repair Tamarac FL
Jun 14, 2017 | Heating & Cooling
Where is the temp sensor located on raypac 185b
The temp sensor is directly in the header. See where the pipes go into the heater, once you remove the cover plate, youll see where the temp sensor wires go into the header, remove the bolt holding it in, and it slides right out.
Aug 19, 2014 | Raypak Heater Part Temperature SensorIID...
TH8110U1003 Touch screen thermostats. My problem is I don't have a manual to show me how to operate it. But the big problem I'm dealing with now is when I set a temp. say I set it for 75 and the house...
If your program that you have programed into the stat is set to 73 it will go back to that setting if the stat is in the program mode....... Push the HOLD button on the stat and keep pushing it till it say permanent HOLD right above the buttons on the bottom and then you can set your temp to what you want. Here is a download link for the manual from Honeywell..
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf
Mar 22, 2011 | Honeywell Heating & Cooling
I keep setting my thermostat but it automatically goes back to same temperature no matter what i set it at
If it is a programmable thermostat, it will only stay at a certain temp until it reaches it or on a set time, then it goes back to the scheduled program temperatures. Most programmable thermostats do have a hold feature that allows you to hold the temp to a certain setting, but if you don't set it to permanent hold, then it does what you described. Hopefully this helps some or guides you in the right direction. Good luck!
Mar 12, 2010 | Heating & Cooling
How do I reset Total copies printed data
hold the go and return buttons down and power up the unit untill there is the mb readings then release. scroll to the right till you reach printer setup hit select then scroll to the right till you reach temp page count hit select to change decimals use the right or left arrow to change them
Oct 11, 2009 | Lexmark T634 Laser Printer
Temp. too hot .how do i ajdust the temp.
for LXIH only
t
urn machine on and wait for "fill" to stop flashing ( bout 5 mins)
open control box drawer by removing the two scews under and to the left and right of the display. then slide if out. careful!! enough electricity to kill an elephant!!
locate control board on the right side. press and hold the small "prog" button. while holding prog press the wash key on the front.
display should read "set 165" this is the temp the insde tank is set to. change it by pressing the small button with the arrow.
press small button with "select" under it. this is the rinse temp (shoud read 190). change it by pressing the arrow button.
press off.
enjoy!
Aug 19, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Changing temp display
Hold down the ambient temp button and the temp down button at the same time for 5 seconds. that should work. It has auto air right, not temp adjusting knobs that rotate.
May 25, 2009 | 2005 Hyundai Tiburon
I try to set the time and temp and just keeps blinking
try to push and hold after you set the time and/or temp until it flashes the appropriate setting then stays solid
if there is a menu button.... time, hour... press till the right hour is on, min.... til the right min is on then menu or ok and either release or hold....
basiclly a process of elimination.
not sure if it will solve your issue. just giving you another option to try.
also unplug and wait 10 sec to let the slow cooker reset before you try again
let me know at sparkallen@aol.com
Dec 25, 2008 | GE Crock Pots & Slow Cookers
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
