Question about Canon MultiPASS MP370 All-In-One InkJet Printer
The printer is not writing on the paper when I try to print something. It is making what sounds to be all the right noises and is going through the motions, but it is not putting ink on the paper. I already replaced the printer cartriges and that did not fix the problem.
    President:
  • 2,571 Answers
If you do not use your printer often, at least a couple of times a week, the ink on the heads can dry and clog up, even changing the inks and doing many head cleans, somrtimes wont fix it.
You can also have problems when the ink tank/sponge for waste ink gets full.
Try a few head cleans, nothing more you can do if you have fresh inks in
Posted on Aug 19, 2010
When i am printing it make a wierd clicking noise, i have replaced the ink in it, and it still won't print properly, it only prints 1/2 lines. I have cleaned the cartridge. Please help
Sounds like something is rubbing somewhere that shouldn't be, so if it continues there is certainly some damage being done.The vacuum suction can sometimes make terrible noise, esp. on rc-papers like Premium Luster et al.
Try to lower "Paper Suction" in the print driver.
Feb 16, 2011 | Office Equipment & Supplies
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Printer will not print off computer
Have you checked to make sure it's plugged in right? Also check your printer settings. I have the same problem sometimes, and I just mess around with those things and it works.
Jan 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Grinding Noise and no printing
grinding is NOT cool...i'd say that you have a mechanism issue with this printer. How long have you know this printer?
Mar 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Won't pick up the paper but the cartridges move up and down the line
Hai Boss it is not the problem with the Catridge . Some of the Spring has begin missing in assemble part . you pull the paper out the problem cause from there never ever pull the paper ..
Feb 12, 2008 | HP DeskJet 970cse InkJet Printer
Paper will not feed into printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
May 07, 2007 | Brother MFC 7420 All-In-One Laser Printer
Won't pick up paper and won't print
Did you have any recent jams that may have left a bit of paper in the printer?
Apr 24, 2007 | HP PSC 2410 All-In-One InkJet Printer
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
35 people viewed this question
old marine
old marine
