Question about Remington Electric Chain Saw
Electric chain saw, motor smoked, stopped running. Worth fixing?
  • 43,501 Answers
Till you get the motor and get the new motor insatlled you will have more into it then a new one...
heatman101
Posted on Aug 19, 2010
Testimonial: "Thanks for saving me from wasting my time,money. "
  • 2 more comments
  • darin311
    darin311 Mar 19, 2012
    I had this happen to mine after the third cut of the day (several hours of use on it already). Smoked a little, then just stopped working. I took it all apart and found one of the brushes not sticking out. Found the string fully depressed somehow, and i feel like it had to come from the factory like that. Because it wasnt pusing on the brush, the brush chipped off a peice. I stretched the srping out and put it all back together and it worked again. I don't know for how long since the one brush is chipped, but we'll see.
  • darin311
  • darin311
    Spring of the brush rather*
  • darin311
    Sorry for my bad spelling and ipad double post. :(
Have a wen 5016 electric chainsaw that smoking probably need a new armature. Dont have parts manual to find exact name . Also cant find anything on the web.
Any help ? Parts illus. or site for replacement?
Posted on Aug 16, 2011
Motor makes a noise when I let up on the trigger.
If it cost more than 300, than yes worth fixing ... but if u paid around 150 for it then no. If u did the repair yourself, yes.. is this an electric chainsaw?.. Junk...
Oct 18, 2015 | Worx Wg303 16" 3.5-hp 14.5-amp Electric...
Motor smoking
throw it away .not worth fixing .
Apr 30, 2015 | Remington Electric Chain Saw
Chain not engaging
I have not worked on electric chainsaws but I do work on gas powered saws. The clutch shoes could be wore out if the saw sees frequent use. Could be something wrong internally as well.
Apr 13, 2014 | Worx (16") 3.5 HP Electric Chain Saw -...
Motor of the saw runs,but chain does not move.
your clutch is bad and how old is this saw if it is too old it would not be worth fixing
Jul 19, 2011 | Remington 16" Electric Chain Saw
Blade were a bit stiff when machine switched causeing the motor to smoke a little and stop
if your talking about an electric chain saw, you have burnt out the windings on the motor and the chain saw is now in need of a new motor. If the saw was less than $100.00 US, you will most likely not be able to get it fixed cheaply enough and might just as well buy a new one. If it is brand new and under warranty, you can most likely get a replacement for free but you will have to contact the actual manufacturer, you can also try the store/dealer where you purchased the saw
Mar 22, 2011 | Garden
Can you adjust clutch 16"homelite electric saw
There is not a clutch on an electric chain saw, it is direct drive when the electric motor ia activated. If the chain is binding it will stop the chain.
Nov 03, 2010 | Homelite Electric Chain Saw
Electric motor on remington chain smoked and quit what should I do
If it is under warranty, then swap it.
If not, then check the brushes.
If they are ok, then repair is most likely more than its worth.
Make sure the switch or cord is not the problem.
Check for a thermo overload reset.
But most likely it is toast, I would guess.
Aug 26, 2010 | Remington Electric Chain Saw
I need a replacement motor for a Remington Electric Chain Saw Model 107624-01 EL8. Anyone have any suggestions.
You can buy this complete saw for about 75.00 on amazon. I've heard of others burning up the field and armature in this model saw. You can buy a homelite electric at Home Depot 50-75 depending on model. Doesn't seem like it would be worth fixing, only to have it burn up again. Sounds like it needs a thermal overload to prevent damage. GOOD LUCK1
Jun 30, 2010 | Remington Electric Chain Saw
You click the trigger the saw starts only for a couple of seconds then runs out of juice.Local chainsaw out fit wont look at it .is worth repairing
the armature is heating up also the bearings could be bad.. on speculation actually you need a new electric chain saw. it will cost more to have that 1 fixed than what you paid for it...
Nov 13, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Unit works but chain stops when pressure applyed, what oil goes resevior.
Does the motor continue to run when chain stops? Electric saws usually don't have a clutch, so I would look for badly-worn chain sprocket, or a possible sheared key in the sprocket hub, or a loose mounting nut. Remove the chain and bar, try to turn the sprocket by hand (wear good gloves). There may be some type of overload clutch built into the sprocket.
May 09, 2009 | McCulloch 10" Electric Pole / Chain Saw
Remington Electric Chain Saw  Logo
1,038 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
