Question about Zenith Televison & Video
I have a 1994 zennith TV/VCR COMBO I am trying to connect a dvd player to. I have one yellow video cord and one double stranded audio red/white cord. I can not get a picture. Vcr player does still work.
    Guru:
  • 276 Answers
Connect yellow from DVD to TV. Connect white and red cables from DVD to TV. Yellow to yellow, white to white etc. Then select on the TV using the remote, the proper input (where the DVD is connected) Press PLAY on the DVD player.
Posted on Aug 19, 2010
How do I connect old school dvd/vcr combo to LED HDTV?
The general rule of thumb is that R-W-Y outputs from the VCR/DVD combo plug into corresponding color coded inputs on the TV. I think the Y(ellow)/VIDEO designation indicates where to insert the Y cord. It's worth a try.
Feb 12, 2016 | Philips Magnavox MWR20V6 DVD Recorder/VCR
CONNECTING DVD/VCR TO CABLE BOX & TV ETC
moz-screenshot.jpgHI-
Check this site for Info's how to connect your device, click HERE
keep me posted for inquiries, thanks!
Jun 30, 2008 | Philips Magnavox DVD/VCR Dual Player
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
How do I connect my philips dvd750vr dvd player to my tv? (tv is a toshiba cx32f60). thanks
it all depends on the cord that you want to use. There are different cords that can be used to connect Tv to your player.
But I would recommend RCA cord. RCA cord is a Yellow, white and red wires. The yellow stands for video, while the white and red stands for audio left and right.
Look at the back of your TV, connect the yellow part of the cord to Video IN, the connect the red and white to Audio IN respectively.
Now, connect the other end of the wires to the player in the format; Connect the yellow to video Out, the connect the red and white to audio Out, respectively.
Turn on your TV and Player. Press source or AV on the TV remote and a display of the DVD will appear on the screewn of your TV.
That would be all.
If you still have difficulty in connecting, please let me know so that I can help further.
Yours sincerely.
Elect_Comp.
May 14, 2011 | Philips DVD750VR DVD Player/VCR
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
g
OK,you need 3 leads,(A/V leads),normally red white and yellow.
So yellow is for Picture (video).go from video OUT (combo) to TV video IN.
Then red and white .... Audio OUT of combo into Audio IN on TV
TV must then be set to AV1 or AV2 depending on which AV inputs you used..
Rod
May 04, 2009 | Televison & Video
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
173 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
