Question about E-Machines eMachines Monitor E15T4
19" E Machine Monitor. Goes black screen on me
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 20, 2010
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Black screen blue light blinking
LCD backlight is faulty. Need repair.
Oct 25, 2013 | Gateway HD1900 19" Monitor
HPW2338h goes black after about 3 seconds. Push power button on, it turns on and then black after 3 seconds. Power light on monitor stays on.
hi,
you can try to change the screen resolution with a spare monitor to a different setting, usually higher 1024X768, then unplug the old monitor and then plug in the flat screen. try different resolutions untill it submits. if you cant get it to run on your machine, take it to another computer and see if you can get it to run on that. if it wont run on either then you have a problem with the monitor. pawn shops usually have flatscreens for way cheaper than new..
jm
Dec 15, 2009 | HP w19 19" LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Black screen
What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Sounds like an insurance claim.
May 28, 2008 | Gateway FPD1975W 19" LCD Monitor
19 in lcd mag monitor
You need to try another monitor, any type. If you find another monitor does functions return the 19" monitor. Most monitors come with a 1 year warranty.
Feb 12, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
"Desact.monitor"
my monitor says desact monitor and I dont know what it means.
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
E-Machines eMachines Monitor E15T4 Logo
108 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
