Question about Car Audio & Video
All seems to be wired correctly but will not save settings - can anyone help?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Make sure the yellow wire is going to a constant power source. (stays hot with key in off position).
Posted on Aug 19, 2010
I need help with a ps3 polaroid wired controller it wont connect
How do you connect it, wired or wireless? Check these settings out.
Make sure the Power Save Settings are turned off: XMB > Settings > Power Save Settings > Controller Auto-Off > Off
If the Power Save Settings were on, then that was your problem. The controller only charges for 5 minutes and then turns off. That is not long enough for the controller to charge. Turning the Power Save Setting off will allow the controller to charge correctly.
If the Power Save Setting is not on, then do a Reset (http://faqsmedia.ign.com/faqs/image/arti... ) on the controller, then connect with the USB cable and press the PS button. If this doesn't work, then I would say the controller is going dead, and you are in need of a new one (make sure to actually press the Reset button, sometimes it can be missed if you are using something too small, like a needle).
Aug 21, 2011 | Video Game Consoles & Games
June 2010 scrambled channels I have lost all channels they say they are scrambled - i have the correct keys installed, the emu is set to on. I have returned to factory setting then re set the emu - but...
dont factory reset the box at any time now redo your codes and make sure you save each line you put in if you dont save the lines you will receive nothing after you have imput both lines and saved them then turn the emu on you should be working ???now can you post the keys you have to help other people
Jun 13, 2010 | StarTech.com StarView SV221DVI 2-port KVM...
Pc keep on going back to default setting when shut down
Sorry but I must ask if you are correctly saving your bios settings at the end. Please make sure you are hitting the correct keys to save and exit.
What BIOS do you have? Then I can tell you which keys to save your new setting.
Jul 20, 2009 | Computers & Internet
No power
i think you have a bad phase or you are not getting the correct volts going in try switching the hot wires red to black and black to red and check each set of windings for continuity
Jun 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
AV1C-N3 problems
yellow wire on back of pioneer unit is probably on wrong wire try switching it with the red wire ........yellow is constant power (saves memory time and last part of song or movie so when you get in the car again it will start from where it left off) if this doesn't work ground it to the car itself (black wire to frame not wire in-dash) try the wire switch first ........hope i was able to help
Jan 31, 2009 | Pioneer AVIC-N3 Car DVD Player
My DLink DR 615 will not allow me to connect to the internet...rechecked all of my hookups and they seem ok Soon as I rehook straight back to the MAC, internet is restored...the router doesnt seem to...
Try checking the Advance setting on your network filter under Advanced. Make sure it is set to Turn MAC filtering off and set the WI-FI protected setup to Disabled. and save the settings .
Jan 03, 2009 | D-Link DIR-625 (790069292637) Wireless...
HP f2105 LCD monitor Backlight inverter problem
Simply open the set and cut that GRAY WIRE ON THE SET OF WIRES THAT CONNECTS THE POWER SUPPLY TO THE INVERTER CIRCUIT. 100 PERCENT WORKING AND TESTED BY ME. (hardwareman25 @ www.gsmhosting.com or email me @ kiwakulecho.gsm@gmail.com )
Oct 31, 2008 | HP f2105 21" LCD Monitor
Toshiba Satellite M45-S169 won't boot
you must restore your bios settings to the correct ones. contact toshiba customer support for the correct toshiba settings.
Jul 27, 2008 | Toshiba Satellite M45-S169 Notebook
Line-rate issue with cisco 878
just a suggestion, there are free modem firmware updates from cisco's FTP site to most 800 series routers. The firmware also get updated with a major IOS release, have you tried?
just download the correct one, instructions are on the site to download. Basicaly you rename the file and save it onto your flash. the check with "sh dsl int" in enable mode, it will list the FW as "external" source. When renamed or deleted, you are back to the original.
hope that will help.
Feb 14, 2008 | Cisco 878 SDSL Security Bundle with Plus...
Car Audio & Video Logo
12 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
