Question about Pentax Optio S10 Digital Camera
Hi , I have a Pentax optio S10 the auto focus has stopped working , sometimes I have a yellow triangle with " ! " and a hand signalling stop , any ideas please ? thanks
  • 724 Answers
Remove the batteries first'
pull the memory stick put it back in
put good (proper milliAmpere hours) new batteries in the camera
If that does not work \turn off the camera
remove the memory stick
Repeat power up
Posted on Aug 19, 2010
  • gallopingfre Aug 19, 2010
    Thankyou Tommya300 , I will try as you say with a new battery plus card , so far when I try it does a small buzzing sound too , maybe an alarm ?
    thanks again
Instruction manual for Pentax optio S10 camera
You can find and download the manual on this site or link http://www.pdfasal.com/cameras/pentax-optio-s10-digital-camera-operating-manual.html- click on the Download link- tick the Check In box and supply the codes then hit Download button
Oct 14, 2011 | Pentax Optio S10 Digital Camera
When i take pictures on my pentax optio s10 the pictures are coming out black but the lcd screen is working, is there anything i can do to fix this?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Pentax Optio S10 Digital Camera
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
My Pentax Optio W10 camera takes some out of focus photos. What do I do to solve this problem?
Your camera has the option for manual focus. This option allows you to focus the camera to capture what you want, rather than the auto-focus feature.
This will be indicated by a MF in the top center of your camera screen. You should be able to change this by finding record mode and changing your AF settings. Change your MF to the [ ] option and you should be on auto-focus settings.
Hope this helps.
Chadlnrd
Feb 28, 2011 | Pentax Optio W10 Digital Camera
Focus not working
Set your camera to factory default settings and try it again. Make sure it is not on Macro setting.
May 19, 2010 | Pentax Optio 50 Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
Pentax Optio S10 - Turning on problem
What kind of shape is your battery in?...old, been charged many times, needs charged, dirty contacts on the battery or inside the camera?
Sep 17, 2009 | Pentax Optio S10 Digital Camera
Optio 30 Focus Problem
Please be informed that the [Firmware Version 1.01 for Optio30] has been released. Changes of the Version 1.01 In very rare case, the Auto-focus system may be malfunctioned at the [Flower], [Food] and [Pet] mode. This has now been corrected. This does not apply to the ther capture modes. Follow link below for more information and to download the firmware. http://www.pentax.ca/support/cs_softwareoptio30firmware.php
Sep 08, 2005 | Pentax Optio 30 Digital Camera
Pentax Optio S10 Digital Camera Logo
93 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
