Now my printer hp photosmart c7280 all-in-one will not come on are do anything . ON the screem it show the picture of the on botton and 83c00020
  • Delsie Roberts Aug 19, 2010
    Will not boot up.Will not shut down or turn on with on button
  • 4,737 Answers
Follow the below instructions:
Remove all the cartridges, clean the contact points on the cartridges and on the printer using soft brush/cotton dipped in alcohol/acetone /spirit.
While the cartridges are kept for drying, do the following:
Turn it off > Disconnect usb cable, power cord, inthernet cable; >remove the papers from the tray >open the back panel door (the rear door where you clear paper jam). Also turn off the mains switch which the dc adapter is plugged in. After keeping it Off for about 5 minutes, turn on the printer again with only the power cord connected, keep tapping the cancel button while it boots up and again leave it On for few minutes > turn it off > connect all the cables > again turn it On and keep pressing the power button while it boots up. Now you can install the cartridges. Check the status message. It should work fine now.
If the problem persists, there must be internal hardware/firmware problem and will be needed to call for service.
Good luck.
Thanks for using FixYa.
Posted on Aug 19, 2010
  • Lebanon Raingam
    Lebanon Raingam Aug 19, 2010
    Well, then Please unplug the power cord from the printer and follow my instructions. Thanks.
I installed a vista driver for my allinone HP photosmart c7280 but the operating system does not recognize my printer. The software has installed though. Is there anything I can do to get Vista to...
Just make sure service "printer spooler" is running. To open windows Vista service under 'Run' type 'services.msc', then have a look that service is running or not. You can just simply right click to start it.
Aug 05, 2011 | HP Photosmart C7280 Printer
I have a HP 6180 all in one printer power error code
Read through NINETEEN(!) other FIXYA "solutions" for the '83C00020' error: http://www.fixya.com/tags/83c00020
Pick the one that works for you.
Jul 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP02 Ink (Expired)
I HP made cars they wouldn't start until you change your dirty motor oil.
May 07, 2010 | HP Photosmart C7280 Printer
What kind of printe cable do i need to connect my photosmart c7280 to my computer usb port
Hello, Joe.
You need to get a USB printer cable ...
Here's a photo of the connectors:
Hope this helps.
Dec 07, 2009 | HP Photosmart C7280 Laser Printer
Error code 83c00020 on screen when power on. help?
The information you have left is a bit limiting however best guess you have a driver problem, worth a try- replacing the driver
The latest version can be downloaded from the HP website
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=us&dlc=en&lang=en&cc=us
If you are unsure how to swap out a driver leave a comment and I will run you therough it
Sep 15, 2009 | HP - HP Photosmart 8250 printer
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
Jun 22, 2008 | HP Photosmart C7280 Printer
Hp photosmart
try this site
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
Dec 07, 2007 | HP Photosmart 2575 All-In-One InkJet...
99 people viewed this question
k24674
