Question about Bosch Integra® 500 SHX55M05UC Built-in Dishwasher
How do I get the handle off to replace the end cap on bosch dishwasher SHX55M05UC
4 Suggested Answers
SOURCE: Bosch Door Handle: Loose
Same here!
Posted on Jul 11, 2008
SOURCE: my bosch dishwasher won't drain
mine is doing this too. I am trying to figure out if its the pump.
Posted on Nov 14, 2009
KevinWhite
  • 1902 Answers
SOURCE: Bosch SHX46A05UC/46 Diswasher - Need
Hello & Welcome to FixYa
You can view this video for replacement:
Please get back to me if you have any other questions.
Kevin
Posted on Aug 21, 2011
Where is the thermal fuse
Go to Utube and copy and paste this in : Bosch dishwasher thermal fuse replacement location . You will be able to fix it yourself with the videos .
Here is the link :
https://www.youtube.com/results?search_query=Bosch+dishwasher+thermal++fuse+replacement+location
Hope this helps , Grant
Aug 11, 2014 | Bosch SHE3AR75UC Ascenta Series 50 dBA 62...
Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
Mar 13, 2014 | Bosch Dishwashers
Bosch SHX46A05UC/46 Diswasher - Need to replace end cap on door located just behind the handle
Kevin
Aug 21, 2011 | Dishwashers
One side of handle brocken
you have to replace one end cap. you must take the door panel off to do this.
Mar 13, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
How do you get the washer to dry dishes? What
Check the operators' manual.Don't use the drying element as it's costly on the electric bill.When the washing cycle is complete leave the door partially open and let the water evaporate
Sep 28, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Loose door handle on bosch integra ltd. dishwasher
you can loosen the inside of the door with a small torx screwdriver and lift it up far enough to get to the screw that holds the handle from the inside. I did this with mine about 1 year ago.
Aug 30, 2009 | Bosch Integra® 500 SHX46L Built-in...
Bosch Integra® 500 SHX55M05UC Built-in Dishwasher Logo
186 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
