Question about Kenmore 53642 / 53644 Side by Side Refrigerator
We have a noise every 5 to 10 minutes -a (ping noise ) like electrical point or contact opening
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 19, 2010
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is loud...
Hi Loretta:
I'd contact the installer. This sounds as if there may be a slow leak. When the gas concentration is high enough it will ignite which would be the bang that you hear. The popping sound could be the flame at the leak source point re-igniting for a few times.
DEFINITELY CONTACT YOUR INSTALLER OR GAS INSPECTOR. THIS IS A SAFETY HAZARD.
Mar 11, 2015 | Dryers
I have a E2EH- 023HB Intertherm electric furnace. The contactors are sparking after furnace is turned on for a few minutes
replace contacters, probably old and pitted (remember points in the distributer on older cars?)
Feb 18, 2015 | Intertherm Heating & Cooling
Huebsch dryer troubleshooting
could be door switch
Mar 23, 2014 | Dryers
The motor is making a knockin sound
A knocking (or sometimes pinging) is a result of insufficiently burned fuel in the cylinders. This can be from bad fuel or from fouled plugs, to bad wiring or bad electrical contact at the distributor.
If the knocking is not this, but a repetitive striking noise, then you will have to locate the area the noise is coming from and try to identify it. Sorry can't be more of a help, this really is a person to car diagnosis.
good luck and don't forget to vote!!!
Oct 11, 2010 | 1998 Saturn SL
Knocking and pinging noise
You might have a blown head gasket. The milky oil is an indication of water getting into it, which would point toward your head gasket. You should have a compression test done.
Jun 21, 2009 | 1995 Chevrolet Lumina
Pinging noise every few seconds
The pinging noise could be a door alarm which sounds if the door is left open for too long.
Mar 02, 2009 | Refrigerators
90 Toyota 4Runner pinging noise
hi the pinging you here is ignition firing before it should but if you have a knocking noise i would suspect the worse but try doing a compression test first see if everything is in order then if this seems ok have you put fuel in it just before it started if so change your fuel if not see if the electrical system has a knock sensor if so run the engine and tap the block close to it see if engine revs drop if not replace but the knock is a piston best of luck yates210456
Oct 12, 2008 | 1990 Toyota 4Runner
White noise on screen with screeching sound
white unstable lines plus screeching noise it basically due to loose contact at input 1 like antena or cable wire or socket loose. 2 loose contact some where in your tv. 3 loose contact in some electrical thing. 4 loose near tuner section. hope this will help.
Oct 01, 2007 | Toshiba CF32F50 TV
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
479 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
