Question about Microwave Ovens
My microwave comes on for 3 or 4 seconds and then shuts off. This just started. For those few seconds I hear the fan and a clicking noise.
  • Microwave Ovens Master
  • 9,098 Answers
You should post a new help request with the same text, but add your brand name and full model number from the tag in or on the oven.
Posted on Aug 20, 2010
Sharp microwave kb-6002ls making buzzing noise
Someone would have to open the unit to "hear" where it is coming from, possible fan issue or even the power unit inside.
Dec 03, 2012 | Sharp KB-6002LS 1000 Watts Convection /...
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Shuts off but everything else works
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 08, 2008 | Panasonic NN-S542 Microwave Oven
Whirlpool OTR microwave no oven 'fan'
FIRST ,,MICROWAVE OVENS ARE REALLY SAFTY MINDED AND THATS A GOOD THING....THERE ARE USUALLY THREE DOOR SWITHCES NEXT THE KEYBOARD--THE ONE ON TOP AND THE ONE ON BOTTOM ARE PRIMARY AND SECONDARY SWITCHES,,YOUR PROBLEM SOUNDS LIKE ONE OF THESE IS NOT MAKING CONNECTION..YOU MIGHT BE ABLE TO PRESS 'DOWN" WITH A LITTLE PRESSURE ON THE DOOR AFTER CLOSING TO SEE IF THE FAN WILL START,,,IF YOU NOTICE --THERE ARE 2 LATCHES(HOOKS) COMING OUT OF THE DOOR,,WHEN THE DOOR IS CLOSED,THOSE LATCHES ARE SPRING LOADED AND MAKE CONTACT ON THOSE SAFTY SWITCHES....THIS IS NOT A CUSTOMER REPAIR--MICRO'S ARE JUST TO DANGEROUS WHEN YOU TAKE THE COVER OFF--IF THIS DOES BRING THE FAN BACK ON--YOU GOT A BAD DOOR SWITCH AND SHOULD BE A REASONABLE REPAIR
THE OTHER SOLUTION STILL WOULD BE A CONNECTION PROBLEM ON THE KEYBOARD ITSELF-THE WIRES JUST PLUG ON THE CIRCUIT BOARD BEHIND THE KEYBOARD---STILL A EASY REPAIR--GOOD LUCK TUNICA
Oct 30, 2008 | Microwave Ovens
Microwave Problems
It may be as simple as a door switch, but it's usually a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on the high voltage section.
If you were to opt for service, I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 06, 2008 | Microwave Ovens
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
