Motherboard manual tbgm01 - Computers & Internet
Need pinout of the front panel connector on a gateway tbgm01 motherboard
What I would suggest is that you look at your current power and led connector if you have the machine and trace the wires back. if you do not have that machine then you will need the serial number and manufacturer of the motherboard. It could be Intel, MSI, ASTRock or Asus in a Gateway FX series which is what it should have coem from.
Sep 22, 2013 | Gateway Computers & Internet
TBGM01-1.0-8
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Sep 06, 2012 | Computers & Internet
Motherboard
What motherboard do you have?
Aug 28, 2007 | Biostar K8M800-M7A Motherboard
Computers & Internet Logo
1,017 people viewed this question
David Payne
David Payne
