Question about Garden
My pancake compressor ran fine for about four months. Then while using it the motor starting kicking on/off, on /off while filling the tank. Then again while filling the tank on/off, on/off, on/off then off and starting smelling as if the motor over heated. Now, it will not come on at all. Can anyone assist with this? Thanks
  • 43,501 Answers
Check the motor capacitor...if it goes bad it will not get the motr running fast enough and will start that on/off thing...
probably burnt the cap right up now...
heatman101
Posted on Aug 19, 2010
My pancake will try to kick on when the pressure drops, however it will not catch and start. It is like a car that will just not turn over when trying to start. Any thoughts?
sounds like it needs a new start capacitor for the motor and never use a extension cord plug it directly into the outlet and use longer air hose.using extension cords for a air compressor is bad for the motor
Jun 19, 2011 | Stanley FactoryReconditioned Bostitch...
I've owned the air compressor for 6 years, but in that time I have only used it less than 2 hours. Recently, I plugged the compressor into the wall plug, and it ran for a few minutes, but then the...
The switch for the starting winding probably has failed shut drawing current through capacitor and the winding even though unit has started. There is usually a centrifugal actuaated switch with contacts that open when motor is near full speed.
Jun 01, 2011 | Clarke Power Products Inc AC2001 2HP 4...
PANCAKE COMPRESSOR WON'T SHUT OFF AND WON'T BUILD PRESSURE.
most likely the regulator is shoot. But also try checking for leaks with dish soap and water in a spray bottle.
Mar 06, 2011 | Clarke Power Products Inc AC2001 2HP 4...
My Bostich 6lb 2 HP oil free compressor was running fine until it kicked while I was using it as it sometimes does and would not stop. It actualy made a high pitch noise and began to smoke for a second...
The regulator on this model is prone to stripping and a kick would do it. Call the toll free number 800.556.6696 with your receipt and you should be able to get a replacement regulator.
Oct 19, 2010 | Stanley FactoryReconditioned Bostitch...
How long does it take for the compressor to fill up during the first use? The motor has been running for 15 min and the pressure needles have not moved....
Make sure the tank drain on the bottom of the tank is shut off if there is one.
It should not take more than three or four minutes to fill a small pancake tank.
You hear any hissing noises while the pump is running? If so, there's an air leak, see if you can stop them somehow.
If the above does not answer, return unit for refund or exchange.
May 12, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
My dad bought a used 2HP 4 gallon clarke pancake type air compressor at an auction. It keeps blowing capacitors. Does it have a centrifical switch to take the cap out of the cct once started?
hi there!
some motor compressor are equipted of centrifugal switch connected at the shatfting of the motor compressor after turning at rated speed this will be open and disconnecting your starting circuit as well as the starting capacitor.
have anice day fix my rate, thank you
May 07, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Husky pancake runs in reverse
I am a little confused here ... I have a Craftsman pancake, a Craftsman 6 hp (same compressor design) and several other name brand pancake compressors at the job. The compressor doesn't care which way the motor runs though mine all run in the same direction. As long as the piston goes up and down, the reed valves know when to open and when to closed based on the pressure. It sucks in from the 'room' on the down stroke and blows into the tank on the upstroke.
Yours isn't doing this? If it is creating a vacuum in the tank, I would have to say someone put the valves in upside down.
This is very curious.
You could reverse the black and white wire but as I understand the physics of it, it will not matter where the hot wire is since it is AC. The motor may be reversable but I'm thinking it is probably not in this case. That costs extra to make into the motor.
Please inspect the valves to make sure they are capable of 'inhaling' (the site will delete the other word I used) on the down stroke and 'exhaling' into the tank on the upstroke.
Please let me know what you find out.
Thanks for your curious question at FixYa.com
Jan 15, 2010 | Air Tools & Compressors
Motor startup trouble while pressure in tank
My first thought was that the check valve is allowing pressure back into the compressor and preventing the motor from turning. That's still my best guess right now.
I think the cold weather start symptom is what you would see with any engine/motor -- it requires more torque to get it going. In this scenario, if the check valve weren't leaking, it would start okay when cold.
May 06, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Oil covering pancake and pressure adjustments
Typically on the inside cover of the electical box it will illustrate the cut-in/cut-out controls. There should also be a fill port above the pump end of the compressor. Do you have a sight glass on the side of the compressor *(around the area of the leaking oil) usually if its coming out its due to overfilling or tipping over of the compressor.
Feb 02, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
