Question about Cameras
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
  • 2,012 Answers
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
Posted on May 02, 2008
I have a Canon G9 and when I playback movies they are too fast. How can I make any movies I take playback in normal motion time?
Posted on Jun 30, 2008
  • bbogos Jun 30, 2008
    On a canon G9 how do you make sure you are shooting movies in the standard mode?
My canon sd790is was playing video back in fast forward also. You are correct it was recording video in "time laps mode" i just switched it back to "standard mode" and it plays back fine now.
THANKS!
Posted on Dec 28, 2009
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
How do i play whats on the memory card nothing plays video only audio. or what do i need to convert it
First, make sure you have it on CARD (and not DISK), and on the "playback" (and not record) mode. Next, does the camera play back other video clips normally, but just not a specific clip ?
Does the selected video clip frame (index) shown on the LCD screen have a picture ? If not, i.e. it is blank (dark), then it is likely that no video was recorded (i.e. just the audio) when you were shooting that video clip.
If there is a picture (of the video clip frame index on the LCD screen) and only audio is playing, try downloading the clip (from the SD card) to your computer, or simply try to play the video on the SD card (inserted directly into your SD card reader on your computer, or via a USB SD card reader) and see if the video clip will play normally on your computer.
Jan 09, 2011 | Samsung SC-DC173 DVD Camcorder
Video playback is too fast
It sounds like you may be in "Fast Frame Rate" video mode. Turn on the camera to video mode, then press right/left to select normal 640 pixel video. (Depending on the camera model, you may or may not have to press "Func" or "Func Set" first).
Jan 24, 2010 | Canon PowerShot SD1100 IS Digital Camera
Video Playback in fast mode (canon ixus 80)
Oh my, sounds like you accidentally recorded in "Time Lapse" mode (one of the specialized video features of your camera). Unfortunately, there's no way to convert the already taken video back to "Standard" video with sound, I'm sorry. However, you'll obviously need to set your camera back to standard mode for future videos. Press the "Function" button while in video mode. Then press left/right to select "Standard" video.
Jul 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Hello I have a Canon Powershot SD1100 IS Digital Elph and I recorded some clips of movies in time-lapsed mode because I didn't realize that it would be fast forward and I was wondering if it could be fixed...
U will have to edit the movie on a video editor ..... Ulead video studio is a good one ....... get ur video on it ...reduce playback speed according to choice and create a new File
Oct 19, 2008 | Canon Cameras
Video too fast during playback on my Camera
I have a Powershot SD1000 and it should be similar.
When the video plays very fast it was probably filmed in Timelapse mode( which fast- forwards the video) When you are in video mode press the SET Button and set the camera to Standard mode
Sep 19, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Problem w/ canon g9 camera
Make sure that you're not on timelapse, it should be standard to do a regular playback.
Aug 04, 2008 | Canon PowerShot G9 Digital Camera
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
Cameras Logo
783 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
