Question about Garden
I have a 1500 series Cub Cadet, 54 inch cut. I ran over a rope that wrapped around the blades shutting down the mower. I turned the mower off and removed the rope. I engage the PTO. I hear it click but the blades won't engage. I can turn all the blades. They all seem to be free. Fuses are OK. Is there a reset? Does the clutch have a sheer pin?
  • 4 Answers
Put the rope back around the blades then go in reverse slowly, park the tractor where you found it prior to running the rope over, get off, shake your head a few times, then try it again, this time pick the rope up first! that should fix ya!
Posted on Aug 19, 2010
  • Dennis Robinson Aug 19, 2010
    put the rope back around the blades then go in reverse slowly, park the tractor where you found it prior to running the rope over, get off, shake your head a few times, then try it again, this time pick the rope up first! that should fix ya!
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Is there a certain way the blades should be when replacing belt on rzt 54 cub cadet mower
If I understand your question. No, the spindles are not timed. This is if you mean where they go as far as rotation.
Apr 11, 2014 | Cub Cadet 42 And 54 Inch Blade Operator's...
Broken Cub Cadet
I dont own one or there but it is an easy repair. Find a wrench/socket that will fit the 3 or 4 bolts holding down the pull cord (recoil) cover and remove them and the cover. (Prob. a 10 mm socket) Then wrap a cord/narrow rope CLOCKWISE around the pulley 3-5 times and prepare mower to start as you normally would and pull the rope. Now you can cut your grass before it becomes unmanageable. Take the recoil to any small engine repair shop and have them replace the rope and then you can reinstall the recoil. In my area the charge $7-$10 for this.
May 20, 2013 | Garden
Cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Jun 21, 2009 | Garden
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
