Question about Brother HL 5250DN Laser Printer
I want reset counter the fuser of my brother HL-5220dn help please
  • 114 Answers
SOURCE: brother hl-5250dn fuser unit faliure
Nothing to do here , you need to change your fuser unit.
Fuser unit make the impression parmanent in the page.
Posted on Feb 01, 2009
SOURCE: Brother HL-5270DN PF Kit Problem
I found the answer in another group, from Sunshine3240:
Open the front cover and leave open while completing the following steps:
Turn the printer off.
Hold the 'go' button while turning the printer on. All panel lights should be on.
Release the 'go' button.
Press the 'go' button 2 times.
Pause.
Press the 'go' button 5 times.
The toner light should be off.
The paper light should be on.
Close cover. The ready light should be the only light on.
Posted on Mar 13, 2009
POCBM
  • 121 Answers
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Posted on Mar 23, 2009
MIlfordPrint
  • 90 Answers
SOURCE: Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Aug 03, 2009
nyilasrobert
  • 627 Answers
SOURCE: BROTHER HL-5170 FUSER COUNT RESET
To reset the drum you have to hold down the go button untill all the lights light up and flash.
Posted on Aug 05, 2009
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
How to reset fuser on my brother HL1870?
You can do whats called a Parts Life Reset Function.
This function is used by service specialists only when changing the periodic replacements parts to clear the life counter. To operate this function, press the "Go" and "+" switches together until the menu "RESET PARTS LIFE" appears on the LCD display. Select the required item "part name", using the "+/-" switches, then press the "Set" switch.
Your fuser error should now disappear.
Hope this helps!!!
Jul 19, 2011 | Brother HL 1870 Laser Printer
FUSER COUNT RESET
The above solution doesn't help, the poster requested how to reset the fuser count replacing the fuser doesn't automatically reset the counter.
Aug 12, 2010 | Brother HL 5250DN Laser Printer
We installed a new fuser into a Brother HL4200CN (Fuser FP-12CL) and it came up with "ID Error for Fuser" Is this a defective fuser or were we suppose to reset a code somehow? Thanks
This message appears when the printer cannot recognize the fuser - probably because you haven't reseted the counter. Make sure it's properly installed. If it is then you will need to perform the reset procedure
1. Press Additional Functions Key
2. Press # key
3. Arrow to number 7, Printer and press Set
4. Arrow to number 4, Printer Re-Set and press Set.
5. Press Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
Jan 27, 2011 | Brother HL 4200CN Laser Printer
Aug 05, 2009 | Brother HL 5170DN Laser Printer
RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
May 17, 2008 | Brother HL 5140 Laser Printer
Brother HL-5140 printer
make sure you have the drum seated all the way in, then unplug the printer and plug it back in.
Feb 20, 2008 | Brother HL 5140 Laser Printer
Hl5270 clear "replace fuser" error
To reset any of the consumables on your HL-5270 you have to press "Go" and "+" at exactly the same time. You will be given an extended reset menu.
Nov 13, 2007 | Brother HL-5270DN Laser Printer
Brother HL 5250DN Laser Printer Logo
375 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
