Question about GPS
Hi, I have a problem with my Audiovox remote starter (pro9555a). The starter will not start my car, nor will it start with the key. I have tried everything.If i turn the key to the on position and use remote the car will start, but when i step on the brake it stops. Any help would be appreciated. Thanks Ed
DarkmanUK
  • 94 Answers
SOURCE: Audiovox car alarm
You can get the installation and owners manual from here....
http://www.audiovox.com/webapp/wcs/stores/servlet/GenProductListCmd?type=model&catalogId=10001&storeId=10001&categoryId=APS155&langId=-1&page=&urlString=&productId=&brand=
Choose your model either th APS155 or the APS155CH
Then click on find manual, save it to disc for viewing or printing later.
Hope this helps.
Please remember to rate.
Posted on Aug 16, 2008
SOURCE: THE ANTI THEFT SYSTEM IN MY 2005 TAURUS WONT DISENGAGE
This is a long shot...I know but for what its worth....
The Taurus has in much the same lay-out as the European Ford (e.g the old Scorpio). You should find two large fuseboxes under the hood near to the windscreen (one each L/R). When driving in rain humidity enters these fuseboxes. This can give ANY funny combination of effects.My car started blinking with headlights, horn waking the entire block and a lot of other fenomenas allthough shut off and key out. Try taking out all fuses (map them on a sheet of paper) and enter some compressed air at short range into each and every fusecontact.
(Just in case ...if you have a towinghook with a connector...do the same with these contacts)
Posted on Aug 22, 2008
  • 462 Answers
SOURCE: I got my remote starter to work when i first got
If the remote start is GM, Start the car, shut it off, Get out, lock the doors, Wait for the front end lights to go out, press the lock button, press the start button. The engine should start.
Posted on Dec 06, 2009
Testimonial: "Thank you so very much. It worked!!!! YIPEEEE"
  • 62 Answers
SOURCE: when using the remote starter the car won't start
have your ignition relay for the remote start checked out.could b a blown fuse.
Posted on Apr 15, 2010
  • 7353 Answers
SOURCE: My 2009 toyota camry won't start. I can't even
try turning the steering wheel back and forth while gently trying to turn the key, sometimes if the wheel is binding, it wont allow the key to turn.
Posted on Jul 24, 2010
How to reset Audiovox Prestige 103bp to work normally
this is a question NOT a solution ........103bp will turn engine over but it is like turning the key quickly and letting it go, it seems the remote starter is not turning engine over long enough to start. Any answers? Onece the car is warm and running or I start it up every 3 hrs , it will start, but if i wait till next day, it will not start the truck
Sep 21, 2013 | Audiovox Prestige 103bp Aps25c Remote...
My truck wont start when i use the remote. the power in the tuck turn on but the truck never turns over. 2006 ford f-150
Sounds as if your immobilizer bypass is malfunctioning. To test, remote start vehicle. Check vehicle cluster (gages). If the immobilizer bypass is the issue, there will be car/lock symbol flashing rapidly. To confirm, put the key in the ignition(do not turn), remote start the vehicle. It should start. If the vehicle starts, remove key, remote start again without key. If the vehicle does not start, have the immobilizer serviced. If the vehicle does not remote start with the key in the ignition, the issue may be with the remote starter's starter output.
Jul 25, 2011 | Prestige Remote Start
I have a prestage remote starter, my car is 2008 ford explorer, after a few days my car will not start, it makes a clicking sound
The vehicles makes a clicking sound when using the remote starter? Does the vehicle make the same sound when attempting to start with key? If so, this sounds like an issue with the vehicle not having enough power to start the car or, there is an issue with the vehicles starter.
Mar 22, 2011 | Prestige Remote Start
I'm looking to get the user manual for a car alarm: aps2k4sflcf.
Go to this site http://auto.manualsonline.com/manuals/mfg/audiovox/audiovox_remote_starter_product_list.html
and click on Platinum APS 686T - Audiovox Remote Car Starter Owner's Manual
and click on APS 686 - Audiovox 4 Channel Remote Car Starter Owner's Manual
Jan 16, 2011 | Prestige APS686T Remote Start and Keyless...
Can you program the cars key fob to start the car for as-tcbm remote start
The Audiovox ASTCBM is nothing more than an immobilizer bypass interface to be used with a remote starter unit. First, you need a remote starter. Then, you may or, may not need the ASTCBM, depending on the vehicle.
Jan 12, 2011 | ASTCBM Generic Factory Remote Start ByPass...
Remote starter does not work after the battery change. How to reprogram it? Audiovox ID:BGAAV2TF
Turn key on and press valet button 3 times then press butoon on remote.Turn key of and thats it
Nov 14, 2009 | Car APS921 Remote Starter - Keyless Entry
How to reset audiovox remote starter
REPROGRAM REMOTES BY FINDING THE VALET SWITCH AND
TURN KEY TO ON
PRESS VALET SWITCH 3 TIMES
PRESS BUTTON ON REMOTE
PARKING LIGHTS WILL BLINK ONCE TO CONFIRM
TURN KEY OFF
DONT LET MORE THEN 5 SEC PASS BETWEEN STEPS
Oct 18, 2009 | Car APS921 Remote Starter - Keyless Entry
My audiovox dealer installed remote starter starts my car then it shuts it off over and over until i put my key in the ignition.
It dosent sound like there is a transponder bypass installed or installed correctlt, I dont know the year make and model of car but that sounds like what it would be
Jun 03, 2009 | Car APS921 Remote Starter - Keyless Entry
Do these work with pus button ignitio
Yes, the remote start can still operate your car, but I suggest not installing it yourself.. Take it to a reputable shop in your area! Push button start cars are different than regular key ignitions, so if you have no experience with remote starts, dont try it.
Dec 11, 2008 | Prestige Remote Start
Audiovox car alrm
what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
Sep 11, 2008 | Audiovox Car Audio & Video
GPS Logo
79 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
