Question about Aurora Electronics AURORA - Aurora paper shredder au-as501mx
Works in reverse but not in forward motion - Aurora Electronics AURORA - Aurora paper shredder au-as501mx
I have lost forward gears on Jeep Grand 2.7CDR taking only in reverse
the transmission computer computer has gone into fail safe mode
an electronic failure not a mechanical failure
could be something simple as a computer re-set or
a transmission solenoid s
will need a jeep service center
or automatic transmission work shop to fix it
Oct 17, 2016 | Jeep Cars & Trucks
The transmission won't move in forward but will in reverse?
get the OBD codes read as will point you in the direction of the fault
Oct 15, 2014 | 2007 Hyundai Elantra Limited Sedan
20822 Department shredder
The motor has a feature to go forward and reverse and thus the forward (paper in) control has been compromised. The problem can be the switches. A rocker switch when in one position may control the forward motion or backward motion, therefore if the switch fails only one side is working. Then there may be two small switches on the so called rollers (Cutters) that sense the input of paper into the cutters thereby starting the motion and shredding procedure. If a sensing device is broken, only the unaffected switch works. Repair is usually expensive, thus a replacement is in order.
Dec 18, 2013 | Dahle Office Equipment & Supplies
Motion sensor
No, the rear sensing system won't signal if you are in any gear except reverse. The wiring for the module is connected so that it turns on when you put the car in reverse. (This assumes the sensors haven't failed. If they are dirty, they can sometimes signal when an object isn't there.) Some newer cars have blind spot monitors that indicate an object approaching from behind and to the side; these don't indicate an object directly behind the car.
I hope this helps.
Nov 10, 2013 | 2005 Ford Freestyle
Intermittent malfunction of reverse/forward motion of automatic T
probably internal ,especially if your car has done a lot of miles/klms,you may need to look further,double check fluid level,shift from rev to drive slowly but still think trans specialist needs to look....hate to say it
Oct 29, 2009 | 1998 Toyota Camry
Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Oct 19, 2009 | Garden
29 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
