Question about HP Vs17 17" LCD Flat Panel Monitor
How do you degauss on the HP vs17 monitor? Can you??? Because i have multiple pixel damages on my computer and i need to know how i can remove it? if you can't degauss, is there an alternative?
    President:
  • 2,571 Answers
The degauss function may help with a poor picture caused by magnetic interference, but if you have dead pixels, i cant see it helping that.
I do not think that TFT flat panel monitors have a degauss function, i have 3 in my house, and none of them have it, just an old 22" CRT that offers degauss
Posted on Aug 19, 2010
  • 67 Answers
You canot degaus and there is no alternative wait until it dies for good the get a new one until then usit like this
Random pixels wrong color
This not good, the problem is in the video processing board that is part of the LCD panel, not cost effective for repair, cheaper to replace.
Mar 09, 2012 | HP Vs17 17" LCD Flat Panel Monitor
Black marks on screen i think it needs a degaus but dont know how to do it
LCD monitors do not need degaussing. They operate in a completely way to CRT monitors.
Tiny black marks are most likely dead pixels, if the black marks are large then the LCD screen may be damaged (cracked glass).
This type of damage cannot be repaired simply, the screen needs to be replaced.
I suggest you put your money towards a new LCD monitor.
Sep 03, 2010 | LG Flatron L1710M 17" LCD Monitor
My hp vs17 isn't starting up. it says that a recently changed software or hardware might have caused this problem. i just don't know how to start it because when i do it redirects me back to that same...
You may not have given us enough info; it may make a difference which computer and/or operating system you are using.
If Windows, try restarting the system and tapping on the F5 or F8 key (not always the same) to reach a short menu with a choice of boot routines. If you have it, choose the 'Safe Mode.' This loads only a minimum of drivers and only a crude video resolution but gives you a chance on examining the settings for normal operation and if needed, removing an offending program.
Jun 25, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My monitor is flashing different colors... it wont start up
chanel_luv_u, Could be possible internal SMPS/CCFL inverter power supply problem. If the PC is ok with different "known-good" monitor connected to PC, then vs17 monitor will need some work done on it. Do some reading here first for some clues!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flatpanel-disolay-blackout-solution/ The first place I would look at on ANY ccfl back-lit lcd monitor that starts doing "very strange things" would be the units "switch-mode-power-supply/CCFL inverter circuit". Try YOUTUBE for video clips of DIY lcd monitor repair to see if unit can be fixed for less than $6 in parts. Keep this in mind though, Your vs17 isn't any different than any other ccfl back-lit lcd monitor in it's basic design and operation. Do some reading of fixya LCD monitor technicians profiles for more info. Let us know what plans you have after you do your research. Bye for now. 12fixlouie
Jun 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp vs17 has white screen at boot. I have eliminated the chord from the tower and the tower works fine. I have audio, no video. Only a white blank screen. It does not blink or flicker. It just stays white....
There are three choices here...bad screen, bad connection, or bad video card, if the card is integrated onto the motherboard, then that part of the motherboard could be bad. If you have access to another monitor or a TV with a vga input, try the computer with another monitor. If you get a signal on that other monitor then you know you either had a bad connection with the other monitor or you lost the screen on the old one. Go back and reseat your video connections with the computer off. Don't ever remove or move cables to the monitor and video with the computer running...the screen can suffer permanent damage. If there is no signal on any monitor, then either you have a bad vga cord or your video graphics card had died.
Nov 11, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Everything is blury have to set screen resolution to 800by600 pixels to try too make any thing out.
Connect the monitor to a laptop -- is it still blurry?
If so, then the monitor is the problem.
If not, then your computer (the video-card?) is the problem.
Oct 31, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Colors are disturbed by magnet
Try the degauss feature
The monitor will have a menu
Use the arrow buttons to navigate
Take a look at this image
Use the degauss, by locating that icon
The monitor will flicker and the shades will be removed.
Hope it helps,
Cheers
Jun 04, 2009 | HP 75 17" CRT Monitor
Screen Resolution stuck at 640 by 480
you first install the audio drivers if the problem persists then attach AGP card then increase resolution and pc will ask question do you want to keep these settings say yes then you can see 1280x1024
Nov 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Deguss
You can not degauss a LCD monitor.
Degaussing is to reallign the magnetic field on a CRT. An lcd has no such field.
http://club.cdfreaks.com/f7/lcd-19-inches-monitor-always-blurred-95364/
The last time I heard of someone wanting a Degauss for an LCD, it was because there kid took a magnet to there LCD monitor. This will destroy the TFT pixels.
http://en.wikipedia.org/wiki/TFT_LCD
Nov 16, 2007 | Proview PL926WBi 19" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
393 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
