Question about Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009
I have an OLD, around 1985 Kenmore chest freezer. I can't get to the model or serial number. My concern is that the left ORANGE light is on all the time as well as the light indicating there is power. It is green. Is there a problem with the freezer ?? I just noticed that the orange light is on all the time yesterday. So far I can't see that there is any defrosting going on . Why is the orange light on ? Control to the right has the 1 indicator ON. Thanks for your help. I work at Sears part time by got no help from appliance person.
5 Suggested Answers
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
tborn6
  • 700 Answers
SOURCE: Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Posted on Dec 27, 2008
buffalonyman
  • 1865 Answers
SOURCE: Owners Manuel for Kenmore Deep freezer
This link will take you to your owner's manual. You can save it as a pdf file
http://www.managemyhome.com/mmh/owner_manuals/search?query=253.9280412
Posted on May 18, 2009
How do i find out how old a freezer is?
Search online to find the manufacturer's website. Call or email them. Be sure to have the model number and serial number. They should be able to help you.
Jan 07, 2015 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Green light on chest freezer flickering?
this just means the light is burning out (loosing its filament) it does not effect the operation of the freezer, it just is an indicator that you have power at the unit.
Aug 30, 2014 | Freezers
Orange light
Good Morning Raj, thank you for your post!
Are you referring to the orange light on the freezer is not working or the freezer itself is not running? May I have the model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the left side wall. With this information I can better address the issue at hand.
Oct 14, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore model 19502 chest freezer green light blinking
My Kenmore chest freezer just went dead today. It ruined my Ribeye steaks, my shrimps and other meats. I will not buy a Kenmore again.
Jan 12, 2013 | Kenmore 5.1 cu. ft. Chest Freezer - White
Chest type freezer Model # TCF1510EW00 Needs a gasket around the door. Where can I get one? Is a Whirlpool Estate chest freezer; serial # EWF1793518 with a date of 090604 stamped on the metal tag.
The part number for that gasket is 4346693 it could be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Whirlpool Freezers
We have an ancient Kenmore Chest freezer. I don't know what the orange, green & red lights mean. Also which is "ON" 0 or -
the light tell you if the door is closed properly or not . Close the door tightly and check the lights. Then open it and check them again this will tell you the positiopn of the door for each colour
Oct 06, 2010 | Kenmore Chest Freezer 16082
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
My kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Nov 21, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 19.7 cu. ft. / 558 liter Chest Freezer 13009 Logo
52 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
