Each time i run the winTV 200 the computer says wintv initialization error.please help me get a solutoin.
  • 67 Answers
Remove the tv card remove the driver then plug in back the tv card and instal the driver thats all
Posted on Aug 19, 2010
WINTV
Which software are you using please give the version
Apr 10, 2008 | Hauppauge WinTV-PVR 350 (WMM32048) TV...
Hauppauge PVR 150 won't work. It used to work,
Did you put in your XP updates before trying to reinstall your drivers?
Oct 19, 2013 | Hauppauge WinTV-PVR-150 (01063) Video...
WinTv Initialization error. hTV=10
HP only supports XP if using vista
so does Hauppauge WinTV-PVR-pci don't support vista
yes if do a restore
it will wipe all your files and data off the disk an be gone forever
please back up your data before you do a restore
Apr 10, 2009 | Computers & Internet
WinTV-T-500 Pixelated screen.
Could be a Ram or Cpu issue. I had a similar problem with ocsasional pixelated picture & discovered my Ram was faulty ( due to overclocking). I replaced the Ram & that fixed the problem.
After another overclock attempt I started getting the same issue as before & realised this time that It was my Cpu causing the issue. By adding a little more voltage to my Cpu the problem was fixed.
This is just to illustrate that the Problem is likely to be a Ram or a Cpu issue, if all else fails. The tuners are heavilly reliant on Ram & Cpu, so any short falls in either can result in an imperfect picture.
Hope that helps...
Mar 02, 2009 | Hauppauge WinTV Nova-t (909) Video Capture
WINTV
Hi, you can download the driver for the HVR-1600 from HERE
(53MB FIle)
Step 1 - Extract the Installer
Download the file to a suitable location on your computer, then extract it . Windows has built in support for zip files, if you right click on the file and select 'extract all' a wizard will guide you through extracting the directory.
Step 2 - Remove the previous software version (if necessary)
If you had previously installed the WinTV-PVR-1600 in your PC, browse to the folder you just extracted to (e.g. through My Computer) and locate a file called hcwclear.exe
Run HCWCLEAR.EXE and choose the options Remove All WinTV Drivers and Applications (Total Removal) and Search All .INF Files for Conflicting Hardware.
Note: wait until the black box has disappeared of its own accord before proceeding.
Step 3 - Reboot
Shutdown and reboot your PC.
IMPORTANT! Once rebooted, please do not cancel any 'Found new hardware' wizards. Also ensure that the original driver CD is NOT in the CD drive.
Step 4 - New Driver Installation
After Windows reboots, you will see some New Hardware Found prompts. For each one, please choose the following options:
4A) On the first page, select 'No, not this time' and click Next.
4B) On the next page, select 'Install from a list or specific location (Advanced)' and click Next.
4C) On the next page you will be asked 'Please choose your search and installation options'. Select 'Search for driver in these locations' and then specify the extracted folder (the folder you extracted in step 1).
Note: Specifiy the 'Driver' subdirectory if Windows cannot find the driver file.
Note: You can also click the Browse button and browse for the directlry created in Step 1.
4D) Keep clicking Next for the rest of the steps then Finish to end the Hardware Installation Wizard
Depending on the model WinTV board, you may see several New Hardware Found wizards. Follow the same steps for each.
Step 5 - Run Setup.exe
Run Setup.exe from the extracted folder (from Step 1). You will be presented with a list of things to install, leave all the default settings and click Install.
Once the installation is complete, all drivers will be installed and you should have a WinTV2000 icon on your desktop.
Apr 11, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Wintv 2000
From the Hauppauge website:
Error Messages when attempting to run WinTV32 or WinTV2000:
Error messages such as: "Error. Cannot locate capture filter", "Cannot build filtergraph", "Error connecting Vcap and HCWCap filters", "Error connecting preview pin" can be caused by bad driver installations. Run the latest driver on the Hauppauge WinTV-USB technical support page to fix this. This new driver runs HCWCLEAR first, and then automatically reinstalls the driver.
Aternatively you may receive an 'Initialization error HTV=## '. Please look in the Device manager to see if the Hauppauge WinTV USB is listed correctly in the Device Manager. If it is not listed properly or if it has a Yellow mark on it, the drivers should be reinstalled.
Also, look under Universal Serial Bus controllers in Device Manager and be sure that the "Universal serial bus controller" is listed correctly(not disabled) as well as the USB root hub. If disabled, re-enable, and reboot.
Jan 02, 2008 | Hauppauge WinTV-Go Plus (85428010335) TV...
Computers & Internet Logo
David Payne
David Payne
