I have a Zenith R45W47. I see arcing at the green tube when I plug it in. Green tube shot?
  • 1 more comment
  • Patrick McAlexander Aug 19, 2010
    Thanks for your response. Is there a way to confirm it is the tube? Could it be something else?
    I did disconnect it from the high voltage splitter and it quit arcing. Is that a sure indication?
    Thank you. You have been very helpful.
  • 10,515 Answers
Arching if the green tube indicates that it is at Fault. You need to replace it and it would be all set.Usually this fault is quite rare on Zenith.
Good Luck!!
Thanks!!
Posted on Aug 19, 2010
  • taran_2005
    taran_2005 Aug 19, 2010
    Thanks for your response!!
    As far as i have seen these sets, it seems to be the tube.
    Note - It has been discovered the cause of the
    arcing has been
    attributed to the Dag coating coming off inside The picture
    tube. This coating is
    conductive and if it migrates to the neck off the tube it
    will cause arcing back
    through the low
    level video drive
    Circuits.
    Look at the below guide :-
    1. The best way of testing a picture tube is by switching the TV set to an empty of channel with plenty of snow (RF noise). If you look see the snow looking sharp in the center of the screen, in the corners of the screen (this is the furthest point from the center of the screen), the snow should still look sharp. However If the snow looks blotchy on the edges of the screen you can safely say the tube is on its way out. Ps as the TV tube becomes old, it might need its refocusing control adjusted.
    2. The second test is the grey scale dynamic test, the TV's black and white scale should be a constant B/W and not tinted in any way with a primary color over the broad range spectrum of the luminance. However when a CTV tube become old they do need grayscale adjustment, this should be done by competent TV technician.
    3. The third test is "flaring", this occurs when the cathodes of the CTV tube are "poisoned", usually by an under driven low cathode voltage say 5.0 volts instead of 6.3 volts on the tube filament operating voltage. A quick test for "flaring; first switch on to a working TV channel, then turn up and down the brightness and contrast control. If you have "flaring", you will see yellow red flaring streaking suddenly appearing on the right side of a color TV screen projected object (usually a distinct red and white). You can revitalize a picture tube by using a B&K tube tester, by "Boosting", which cleans the cathodes of the picture. This usually gives you an excellent picture for about a week or two.
    4. I have had a "man of the cloth" who put one across me when I was ordered to check out a CTV set for a Trade-In. Unbeknown to me, "the man of the cloth" had paid a repair person to install a skillfully concealed 9.3-volt picture tube filament transformer. After the technician had readjusted the set, the "man in the cloth" rang up for a trade-in valuation. I had no picture tube analyzer (considered too expensive to purchase) and the CTV picture tube appeared okay to me. Outcome was that the dimwitted sales representative gave an overgenerous $400 valuation for the trade-in on his TV set, a make and model of which was renowned as having a bad service reputation. Furthermore, the sales representative informed me that it was none of business in the valuing of TV sets; I was only to check them. Subsequently the ctv picture tube only lasted two weeks on the showroom floor, and course it was my entire fault.
    5. Therefore, to check picture tubes one should always use a B&K Tube Analyzer, tester, or something similar.
    Good Luck!!
    Thanks!!
I have Zenith rear projection TV Model IQC60H95W.The blue tube does not work. The red and green project. Is this a bulb or tube and are they available to purchase? The TV was made in 2001
This is a CRT(cathode ray tube) not a bulb. A Bulb is totally different. If you replace one Tube, you need to replace all 3 or the colors will never match properly. However, This model no longer has parts available. Even if they were, the cost would be close to $1000 in parts. I would not recommend repairing this TV.
Sep 14, 2014 | Zenith Televison & Video
Zenith 25" model z25x22s has hardly any green
Check the green output section circuit at the video output card for any loose soldering. This card can be located at the neck of the picture tube itself, will directly plugged to it. You can pull it out of it for repair. Re-solder all the suspected solder terminals there.
If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 16, 2013 | Televison & Video
I have a Zenith SB2531N console tv. I think the tube is going out on it. The picture is green for the most part. Every now and then it will flicker in clear and the picture will be fine for a while. Want...
Zenith was very well known for having bad pix tubes...and it was usually the green gun that was affected...there is a place in Illinois that carries the zenith line of replacement parts ... the website is www.ued.net and the name of the co. is Union Electronic Distributors....you may need to go to the website and get their ph # to talk to a rep....you will need the model no and serial no of the set to get a replacement tube...a word of caution though...pix tubes are very expensive ,,,,so dont be alarmed if it costs 500.00 or more
Aug 15, 2011 | Televison & Video
My tv is blue. no red & green
Please check if the red and green tube have lights.Then if the green and red tube have no lights the problem is in the driver board of your tv.It is a major repair and need to check the repair technician.
Jul 06, 2011 | Zenith Televison & Video
Zenith Projection Television R45W47
Ur tv the convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are defective still have some life left,it will causes colors lines like RED,GREEN,BLUE misaligns,colors shadows,3D picture.When the 2 STK covergence ICS are totally dead it make this cricket noises and burning smell.The shop cost u $300-350 for parts and labors.
Jun 15, 2010 | Zenith R45W47 45" Rear Projection HDTV
Colors going bad on my tv?
The picture tubes in Zenith sets (I assume it's a Zenith since you posted this with a Zenith heading, although it's also true for any set this old) were only expected to last around 7 years. Your description makes it sound like you are missing green, or that the green is just way low. This is a common sign of a bad picture tube. There are other possible causes, but tube failure is the most likely. The low replacement cost for small TV sets makes repairing this one uneconomical.
Get rid of the set and treat yourself to a new one.
Jan 25, 2010 | Zenith SY2068DT TV
TV Turns green and shuts off and less than 5 seconds.
In that TV its usually a bad picture tube. The green element of the tube is shorting.
Mar 13, 2009 | Zenith D32D51 32" TV
ALL GREEN
a picture tube is finishing needs rejuvenation if no one can do that, buy another tube.from
www.freelists,org/archive/techassist/01
im positive it will work with good quility picture.
Jan 06, 2009 | Zenith B25A02Z TV
Problem with the color on my Zenith
picture tube need a picture tube reguvinator $1300
Apr 29, 2007 | Zenith C27A24T 27" TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
