Question about Dell 924 All-in-One InkJet Printer
Dell photo 966 error 1243 incorrect cartridge
After refiling the cartridge i got this error, nothing has change,the printer just don`t want to recognize the old cartridge.
Is it a refilled cartridge? if it is it wont recognice it u should just buy a new one or keep printing if it lets u because i had the same problem and i had to get a new cartridge because it wouldnt let me print at all
Posted on May 12, 2008
Dell all in one printer 964... Error message 1203... What does this mean? I recently had the ink refilled at Walmart. The printer did work after the ink was refilled, but now it's being very odd and will...
Hi there
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
All the best Pineworks
Apr 27, 2010 | Dell 966 All-In-One InkJet Printer
My dell photo 966 says'left cartridge missing Insert black or photo cartridge'.I've put in a new cartridge but I still get the same message.
the contact that detects the left cartridge may be dirty or not functioning at all. clean it with cotton and 100\% isopropyl alchohol then reinsert the cartridge. if it still doesn't work, it must be replaced.
Nov 06, 2009 | Dell 966 All-In-One InkJet Printer
I can't locate the cartridge on the dell photo 966 all-in-one. HELP
Be sure the power cord is in place. and the power is turned on. Next lift the lid and give it time and the ink cartridge will come to the center or left side so you can change them.
Hope this is helpfull to you. Sawdust46
Aug 19, 2009 | Dell 966 All-In-One InkJet Printer
Refilled Ink Cartridge on Dell 966 all-in-one,how do i reset it?
I had this same printer but never was able to reset it. It has some type of sensor on it. That will not let it reset. I was told to unplug it from the computer. Turn the printer off. Reboot the system and plug the USB connector back into it once the system is booted. You may also try to reinstall the printer driver. I also find out that when the printer software says that the ink is low, it really is not. So keep on printing. What I eventually had to do is get a HP. No problem with HP, I can get a refill and it works. Now that I am think about this. See if you can disable the ink monitoring option in the software.
I hope this helps.
Please rate.
Feb 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell 966 all in one printer
when you replaced the cartridge you didn't ran a page Alignment go to control panel
printer options
go to properties and
run a page Alignment
Jun 05, 2008 | Dell Office Equipment & Supplies
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell printer all in one 966 error 1243
if u have the new cartridges then replace it with the refill, it will resolve your issue
May 02, 2008 | Dell 924 All-in-One InkJet Printer
Changing ink cartridge in dell photo 966
It's probably located under the scanning bed.
Look for another section break below the scanning bed.
Lift it up. The print cartridges should be inside.
Mar 25, 2008 | Dell 966 All-In-One InkJet Printer
Dell AIO 962 printer faulty
The error you are referring to could be related to either the cartridge or the printer, so please perform the steps below to check if the issue lies in the printer or the cartridge.
Power on the printer and open the top cove, the cartridges will align in the middle of the printer, remove both the cartridges form their slots and interchange them, yes put the Black cartridge in the Blue slot and the Color cartridge in the Black slot, then close the top cover of the printer and power off the printer and restart it, at this point of time check if the error message is changed or not if the error message is not changed and till showing the same as “Right cartridge is incorrect” then you can try to update the printer firmware form the Dell support site, here is how you can do it.
  1. Go to
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers.
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
If the issue is still not fixed after you upgraded the firmware then I believe that you will have to replace it. However if the error message changes to Left cartridge incorrect after you have interchanged the cartridges earlier then try these steps below.
  1. Remove the color cartridge and clean the metal contacts of the cartridge with a dry cloth thoroughly please make sure that you are using a soft dry cloth to clean the metal contacts of the cartridge.
  2. Make sure that the cartridge holder snap which sits on the top of the cartridge is fixed firmly.
  3. Make sure that you are using a Dell branded cartridge and it is not a refilled one cause Dell printers often give error message when you use a refilled cartridge or a cartridge of some other brand.
  4. If the issue is still not resolved replace the color cartridge.
Malik Khan
Jan 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
134 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
